Si B’s 1/35 Zvezda T34-76 Mod 1943 Uralmash
  • Si Benson
    • 3572
    #121
    Thanks very much gents :smiling4:
    The T34 has slowly been chugging onward , slowed by the need to remove and re-do the ice cleats and straps.
    So there is the front fenders to fit and a few bits here and there. But really not far from paint :smiling4:
ID:	1138996Click image for larger version
ID:	1138997Click image for larger version
    thanks for looking in :thumb2:
    • BattleshipBob
      • 6807
      • Bob
      • Cardiff
      #122
      [ATTACH=CONFIG]n1138996[/ATTACH][ATTACH=CONFIG]n1138997[/ATTACH][ATTACH=CONFIG]n1138998[/ATTACH]
      Very nice, apart from that horrible green, i am off to hide!
      • adt70hk
        • Sep 2019
        • 10435
        #123
        Great work Si.
          • 15764
          Hi Si
          Looking good. A really nice, neat build. Painted by Christmas
          • Graeme C.
            • 1613
            • Graeme
            • UK
            #125
            Very Nice Si, now for a coat of that green Bob likes so much!
            • Steve Jones
              • 6615
              #126
              Awesome build Si. Looking forward to seeing the wet stuff. Looks like you had a lot of fun with this build
              • Si Benson
                • 3572
                #127
                Thanks kindly for looking in gents :smiling4:
                Finally got time to get some primer and a base coat of Ruski-greenski on the T34.
                Cracked open a fresh jar of Mr Primer surfacer and had a squirt....
                Then out with the Mig 4BO modulation set. Base colour first...
                Will let that cure for a bit then a squirt of the next colour.
                • Si Benson
                  • 3572
                  #128
                  Thanks for looking in chaps :thumb2:
                  Been busy with a chinook and attempting some daringly high, high lights with this.....:surprised:
                  first light colour.....
                  Then additional highlights....
ID:	1142206Click image for larger version
ID:	1142207Click image for larger version
ID:	1142208Click image for larger version
                  Also cut a stencil for the turret number to add.
                  So yes it’s a bit psychedelic but if I get it right it’ll all tone done as I go through the weathering stages.
                  Thanks for looking
                    • 15764
                    Hi Si
                    I like the look of the paint job. I think if you are going for colour variation you hve to go a bit harsh at first. If you make it subtle to start with the weathering will all but obliterate it. The other thing is to ensure that the highlights are in the right places. You seem to have it spot on. Look forward to how it turns out.
                    • JR
                      • May 2015
                      • 18273
                      #130
                      Si.
                      Love the way you do these, fitting the tracks and then being able to remove them, I could never achieve that.:fearful:
                      Highlight look good, bring on the weathering.:thumb2::thumb2::thumb2:
                      I can see the "DOGS " award being awarded here.
                      • scottie3158
                        • 14231
                        • Holbeach
                        #131
                        Si,
                        Loving the paintwork mate, looking very nice indeed.
                        • Si Benson
                          • 3572
                          #132
                          Jim, John and Scottie..... thanks for looking in. Glad you like it so far :smiling4:
                          • spanner570
                            • 15466
                            #133
                            Neat work Si. A pleasure to quietly watch it all come together. :thumb2:
                            • Si Benson
                              • 3572
                              #134
                              Cheers Ron,
                              A nod from your good self means a lot sir :smiling4:
                              • David Lovell
                                • 2186
                                #135
                                Great work Si ,I presume the primer was mr color stuff what number was it ,I think the highest is 1500 higher the number the finer the pigment ,used with mr colour se lf leveling thinner it lays on just so easy and smooth ain't the word,are you going to gloss coat before weathering I can never make up my mind some times I do(kleer) others I don't always think it looks more organic without like how it should be ,looking forward to your next move. Dave
