Now my blown-up M113 is almost done, I can almost begin with the next model I intend to make:
[ATTACH]405072[/ATTACH]
I’ve not built a Tamiya kit in ages, so I suppose I’ll find myself surprised at the ease of building compared to most of the recent kits I’ve made
Also, as per usual the name on the box is not for the purist
The designation “M4A3E8” only applied to the prototypes and test vehicles with HVSS (horizontal volute spring suspension), but the “E8” suffix has come to be applied by enthusiasts and modellers to pretty much any M4 medium tank with that suspension. Properly, this tank is probably best described as an M4A3 (76) HVSS, to reflect it’s an M4 with the Ford V8 engine, a 76 mm gun and the aforementioned suspension.
Anyway …
Open the box and you get:
[ATTACH]405073[/ATTACH]
Here’s the sprues:
[ATTACH]405074[/ATTACH][ATTACH]405075[/ATTACH][ATTACH]405076[/ATTACH][ATTACH]405077[/ATTACH]
I probably won’t be using the tracks, as I also have these from AFV Club (two of the eight sprues shown):
[ATTACH]405078[/ATTACH]
Though the T66 tracks Tamiya provides were more common in 1945, these T80 ones also appeared very late in the war.
Of course, I can’t just build it as-is
The idea is to build it as a tank prepared for shipping overseas. This means all openings will be covered with tape with waterproofing stuff sprayed over it, and there will be some boxes on the engine deck. I’ll probably replace a few bits with ones from my spares box, because (for example) it seems rather a waste to use the nice cupola with clear viewports when that will be entirely taped over.
Anyway …
Here’s the sprues:
