I hope so … I’m still not 100% convinced, but the more I look at the bits I painted on the actual model, the more I think the seams need filling
Meanwhile, here’s the painted wheels and suspension bogies:
[ATTACH]406731[/ATTACH]
Nothing spectacular, because most of this will be covered in black goo later
And I finished taping up the turret:
[ATTACH]406732[/ATTACH]
I now need to settle on how to fill the seams (and whether to) before I can continue, because I also need to glue the turret to the hull and fill the gap between the two with more tape. I’d rather have the two parts separate while I deal with the seams, because that will make them easier to handle.
I’ve glued them to the pallet, but still need to add the metal straps that held them on. The whole assembly will stay loose until after painting, so I can spray it in a slightly different shade of OD from the tank.
After doing a test on the actual model this afternoon, on the tape under the exhaust at the rear, I decided that yes, acrylic gel was the way forward. Just now, I did the rest of the taped-up patches, which wasn’t nearly as much of a chore as I had expected it to be. Far simpler than the tape itself, certainly
[ATTACH]406885[/ATTACH]
Hopefully, I didn’t apply too thick a coat, as the intent is to fill the gaps and add perhaps a suggestion of more folds than there really are, but not obliterate the tape.
At this point, I remembered I had forgotten the tail lights, so I stuck tape on them on as well:
[ATTACH]406886[/ATTACH]
The kit comes with two sets of tail lights, one far better detailed than the other, so guess which ones are underneath the tape here I also filled all the holes for the pioneer tools, but haven’t sanded and scraped it down yet,
You can also just see black by the exhaust, which is because after the “test” gel there had dried and looked good, I painted it black to see if it still did in its eventual colour.
After glueing the turret to the hull, in the 6-o’clock position, I added bits of masking tape not cut into strips yet:
[ATTACH]406934[/ATTACH]
This is because when I did the gun shield, I found too many gaps falling between the pieces of tape. By doing it like this, there won’t be (nearly as m)any, and I don’t absolutely need to have the thin strips overlap. As you can see in the next photos:
[ATTACH]406935[/ATTACH][ATTACH]406936[/ATTACH]
Also note the white plastic where I added the tow cable holder bracket, that Tamiya forgot to include on the model. From Son of Sherman, I determined the tank in the kit would have been built in October 1944 at Chrysler, when the forward cable bracket was in this position.
With all that done, I added horizontal edging strips all around, top and bottom, like is shown in photos of the real tanks:
[ATTACH]406937[/ATTACH]
After taking that photo I smeared more superglue over it all, which was tricky in places because some are hard to reach even with a cocktail stick (never mind my fingers) and I had to be careful not to poke through the tape. Once the glue is dry, I’ll do a layer of acrylic gel here too, and then I can finally get on with finishing the model. I hope
Jakko, I thought I stumbled onto a King Tut tomb and discovered a mummified Sherman :smiling6: Even the mighty Tamiya can miss and miss-mold a part. Good spotting it.
It's definitely water proofed now. :thumb2:
It does look a lot like that, now you mention it
TBH, I don’t think my next M4 will be a Tamiya kit … Maybe they designed this one on a Monday morning, but it’s probably the least-good Tamiya kit I’ve ever built. On the other hand, it comes with sponson bottoms, so they did finally manage to figure that bit out.
If it has a sponson bottom perhaps it's not a Tamiya kit but a re-box from another brand. Haven't bought any Tamiya kit for a while so don't know what their state is like now. I thought their new kits were detailed and fit perfectly?
