Scotties meat chopper.
Bob, You will be pleased to know i have made a start, read on.
Think infantry assault across open ground against four 50cals. The aftermath was like an abattoir in a field, hence "meat chopper". Pretty gristly. I believe I read somewhere this nickname came about when an M16 was used to support an infantry unit being counterattacked in the bocage. PaulEComment
Thanks for hanging on, I made a start today. I wasn't going to show the engine and just use the parts I needed to fix prop shafts etc. But there is so much detail it would have been a shame not to. The gearbox alone has 24 parts. So the engine was built complete with teh addition of some etch and some homemade HT leads. It still needs to be cleaned up as I have noticed a few joint lines I have missed then some paint.
the rest of the wiring/plumbing will be added when fitted.
cheers
ScottieComment
Cracking start Paul.
I've been doing something very similar myself today - adding HT leads to a straight 6. Was quite pleased with it until I've seen how good yours is :smiling5:Comment
Thanks Greg cheque is in the post.Comment
Nice start Paul. I need to apologise as well, I can’t find my pictures at the moment....if I find them I’ll post them later on....Comment
Si, thanks, hopefully with a bit of paint and weathering it will be ok.Comment
Thanks Andy, I built that a while ago and have some pictures of the engine I built if they are of any use. I also have some pictures of the actual vehicle.Comment
