Scotties meat chopper.
  • scottie3158
    • 14221
    • Holbeach
    #91
    Originally posted by Jim R
    Hi Scottie
    Cracking work. Looking great and you're mastering all the itty-bitty bits.
    Happy Christmas to you and yours.
    Originally posted by Si Benson
    Seasons greetings Scottie,
    Coming along very nicely ,it may be a bit tricky but it certainly does look well detailed :thumb2:
    Scrooge MacTavish here :smiling:
    Looking good Paul, 2 things, first is the reason why I stick to 4BO !
    Second , how on earth you can work with something so complex, think It would beat me .
    All the best for Christmas to you and the good lady . Hopefully we might be able to meet up again in a couple of years time at Peterborough.
    Originally posted by outrunner
    Looking well Paul.
    Andy.
    Originally posted by Wookie2486
    Scottie,
    Looking good mate.
    Merry Christmas and a Happy New Year to you and your family.
    Marty
    Originally posted by adt70hk
    Paul,
    Apologies for a bit behind on this. Looking good so far. Well done for persevering.
    ATB.
    Thank you all for the fine comments, and seasons greetings to you and yours.
    • BigGreg
      • 2183
      #92
      As usual Paul your skills and attention to details is fantastic..... keep it coming..
      • scottie3158
        • 14221
        • Holbeach
        #93
        Many thanks Greg, glad you approve.
        • scottie3158
          • 14221
          • Holbeach
          #94
          Not a lot of bench time. Built the front winch and bumper again a lot of parts when fewer would have achieved the same. Added bolt and rivet details.
          Removed the moulded on tie downs and replaced them with copper wire versions.
          cheers
          Scottie
          • Mini Me
            • Jun 2018
            • 10711
            #95
            Very delicate......and much improved. Rick H.
            • rtfoe
              • 9101
              #96
              Scottie, the tie downs are the stuff I normally have no patience to do yet you guys do it like it's a matter of fact. :smiling6: That really amazes me. Very nice front end with all the nuts & bolts added.
                • 22771
                #97
                Great work so far Paul.
                  Can’t speak for Paul, but I find them very tiring/trying to add. However, once you do one, you kind of have to keep going with at least the visible ones, IMHO …
                  • scottie3158
                    • 14221
                    • Holbeach
                    #99
                    Thanks Rick.
                    Richard, I'm surprised I have the patience to do them but they are worth doing. Normally the etch ones are to flat and nearly impossible to make them stay on.
                    Thanks Ian.
                    Jakko, they are tiring but I think they are worth it in the end the hard thing is trying to keep them the same size.
                    • scottie3158
                      • 14221
                      • Holbeach
                      #100
                      Some more added to the chassis. the front axle has been fitted and some linkages that should have been fitted in earlier stages. All the parts were sprayed black and then a light coat of OD just to make it easier later on.
                      The end of the exhaust was drilled out and a clamp added.
                      cheers
                      Scottie
                      • outrunner
                        • Apr 2019
                        • 2420
                        #101
                        Looking sweet Paul.
                        Andy.
                          Agreed on all of those points Though usually I’m satisfied with the kit-supplied version, sometimes you don’t have a real choice but to replace a lot or all.
                          • scottie3158
                            • 14221
                            • Holbeach
                            #103
                            Looking sweet Paul.
                            Andy.
                            Andy, very kind of you ta.
                            Agreed on all of those points :smiling3: Though usually I’m satisfied with the kit-supplied version, sometimes you don’t have a real choice but to replace a lot or all.
                            The kit ones can look ok but another reason I like to replace then where possible is I do use them to tie things down by passing the strap/rope through them.
                            • Steve Jones
                              • 6615
                              #104
                              Feeling your pain mate. Just done six of these on my Stug. :smiling5: :thumb2:
                              Outstanding work Paul. Keep up the great work my friend
                              • Fernando N
                                • 2448
                                #105
                                Hi Paul, just caught up with your fine work and a great subject to build
                                Think I have some pics of a M16 and a M45 mount if you want them, the Overloon and NMM museums here luckily have a great afv selection:nerd:
