Beautifully executed. PaulE
Medium Tank M3 from MiniArt — not a Sherman for once!
Thanks allI have one or two variants of this tank in mind that I want to build, but I think I’ll try a Takom kit for the next one … and if I buy a MiniArt M3 medium again, it won’t be with interior
Thanks. The good part is that just about all of those small details are already in the kit, so anyone with a bit of experience should be able to build a convincing model with not that much effort
Last week I was looking at some reviews of the Takom M3s, and the difference in what the sprues look like, compared to the MiniArt version, is the main thing that jumps out at you. Takom’s version is clearly intended to be a quick and simple build, whereas MiniArt’s seems more intended to be complete rather than simple to make.
But the number 1 reason I’ll be going for Takom is that I saw a photo of an M31 armoured recovery vehicle that would be cool to build, and only Takom has that variant in its rangeComment
With the interior done, I taped up almost all of the openings:
[ATTACH]417936[/ATTACH]
Then I put the 75 mm gun in place, without glue, and glued the roof on:
[ATTACH]417937[/ATTACH]
This makes it all a little tricky in that I have to be careful not to touch the tape, as it’s got the sticky side out, of course. I’m thinking maybe I should just paint it to get rid of that.Comment
Thanks, Mike.
I began adding tools and stuff to the outside, for which all the brackets and tie-downs are etched brass. The brackets are doable, but the tie-downs … maybe for other people, but not me.
[ATTACH]418036[/ATTACH]
There’s a bend line on the other side as well. You’re supposed to bend them so the middle, straight part is raised up above the level of the rounded ends. The real thing is a piece of bent steel wire welded to the tank, and the round bits represent the welds. I tried making one (as you can tell from the fret) and found it exceedingly awkward to even hold, never mind bend like it’s supposed to, and then one of the ends broke off. Rather than mess around and waste more, I fell back on the method I tried and found workable on my blown-up M113.
I first punched 0.6 mm discs from 0.25 mm plastic card and glued them in pairs where the tie-downs go:
[ATTACH]418037[/ATTACH]
You’re on your own as to where they go, by the way: MiniArt shows it in the instructions, but not in a way you can accurately work it out, and there are no locating marks moulded onto the engine deck for these (unlike for the other etched bits).
After that, I glued lengths of stretched sprue over the pairs of discs:
[ATTACH]418038[/ATTACH][ATTACH]418039[/ATTACH]
I used Tamiya Extra Thin for the discs, because it remains “wet” for a fair while and the fine brush let me put a dot of it pretty accurately. However, I found it melts the sprue too easily, so for that I used my normal glue, the degreaser I’ve mentioned before. This evaporates far more quickly, so it doesn’t have the opportunity to melt the sprue much.Comment
Thanks, and though this is my first MiniArt kit, I would say you’re probably right about their parts …Comment
Andy.Comment
I wouldn’t go that far, but thanks
Things you can’t see, I generally don’t bother with, but with that clearly visible plumbing on top of the engine, I think it should be there on the model too.
I can manage most of what’s in this kit, and like I said, I think it does actually add something to the model. However, a few spare tie-downs would have been welcome — for practice putting them together, if nothing else.Comment
The finished engine deck, with tools, tow cable and straps to hold them down:
[ATTACH]418234[/ATTACH]
I made the cable from copper wire from an electrical cable and the straps from thin plastic card, but everything else came in the kit.
While I was working on that, I also finished the front of the hull:
[ATTACH]418235[/ATTACH][ATTACH]418236[/ATTACH]
The cabling to the headlights isn’t supplied, but MiniArt does tell you where the cables go, so I drilled holes to put in some thin copper wire before adding the etched headlight guards. I had to replace the right convoy light by one cut from a Sherman headlight, because one moment I had the kit’s part in my tweezers, and the next moment, I didn’t
After also adding the side doors, driver’s vision port, etc. I think I’m done with construction:
[ATTACH]418237[/ATTACH]
… other than the tracks, which I haven’t started on at all yet.Comment
I made a jig to assemble the tracks:
[ATTACH]418505[/ATTACH]
It’s just a strip of wood with three slats of 3 by 6 mm glued to it, so that there is 13 mm between the outer two. This lets me assemble the track with the inner face (and thus the guide teeth) down, while the high sides prevent the end connectors from slipping out of the link half before the other part can be glued over them.
On to the tank itself. I primed all the metal parts and their surroundings with grey Vallejo Surface Primer from an aerosol can:
[ATTACH]418506[/ATTACH]
Once that had dried overnight, I sprayed the whole model with Gunze Sangyo … sorry, Mr. Hobby H52 olive drab. Here’s just the main pieces:
[ATTACH]418507[/ATTACH]Comment
