Polish armoured defence against blitzkrieg
  • Steve-the-Duck
    • Jul 2020
    • 1731
    • Chris
    • Medway Towns
    So, here's the WIP of my 28mm Polish armour. So many Vickers variants!
    Vehicles and figures are all from the Warlord range
    Left to right - 7TP twin turret, 7TP single turret (early), 7TP, Vickers E single turret Polish, Vickers E twin turret
    And now here they are with Wz.29 armoured car and TKS tankette, in overall Polish yellow-grey
  • Steve-the-Duck
    • Jul 2020
    • 1731
    • Chris
    • Medway Towns
    So, now the how we got here pictures:
    Warlord only do the single turret Polish Vickers E with larger intakes, so, time for a LOT of filler, and a template off the twin turret standard 7TP
    Comparison to the twin-turret 7TP (without tracks fitted)
    My modified T-26 into a Bolivian basic Vickers E(A) for comparison
    I dug out the intakes because the moulding does not look great
ID:	1145888Click image for larger version
    The single turret Vickers has the turret on the wrong side; as you can see the driver would be squeezed up in the front. So, more filler, more drilling!
    Warlord do a sets of tank crew figures for their vehicles, and most have separate heads so you can change them about... Especially with their French. Plastic arms are from their multipose British infantry
ID:	1145891Click image for larger version
    Repkacement grill from rod. It's, okay...
    ...but better with the frame round it
    Turret supports added. They're moulded on their T-26s, but not here
ID:	1145895Click image for larger version
    Driver and replacement hatch
ID:	1145897Click image for larger version
ID:	1145898Click image for larger version
    There are holes to mount lights, but none supplied. Again, the T-26s have them moulded on. So rod and the noses of a couple of spare shells, and we're good
    And undercoat - Halfords Grey Primer
ID:	1145901Click image for larger version
    • Steve-the-Duck
      • Jul 2020
      • 1731
      • Chris
      • Medway Towns
      And now, the 7TPs. On the left, the stock model. The twin turret version has the early hull, as also used by the first production single turrets
ID:	1145903Click image for larger version
      • Steve-the-Duck
        • Jul 2020
        • 1731
        • Chris
        • Medway Towns
        TKS Tankette with 20mm FK-A cannon, which turned out to be nghtmare for the Germans - too small to see but heavily armed enough to take out most panzers. Possibly the only time any Carden-Lloyd-based gankettes were ever useful
        I've replaced the soft and bendy barrel with aluminium tube, with the original muzzle brake added
          • 15737
          Hi Steve
          They look great. Really neat alterations especially at this scale.
            For anyone wondering how small this thing actually was:—
            This is the version armed with a machine gun, so the one Chris built would have even less room inside
            • Steve-the-Duck
              • Jul 2020
              • 1731
              • Chris
              • Medway Towns
              I've got the IBG 1/35 20mm armed TKS, bought to get the Hakata Polish colours. It's small enough for me to keep...
              I inted to use the TKS to make a C2P tractor. My 'spare' 7TP is going for a C7P artillery tractor
              I COULD do a TKS with an interior, using the IBG kit for reference...
              • Mini Me
                • Jun 2018
                • 10711
                Lovely work with all the mods....makes a very interesting collection. Thanks for sharing. :thumb2: Rick H.
                • Steve-the-Duck
                  • Jul 2020
                  • 1731
                  • Chris
                  • Medway Towns
                  On with the green. This is the Hakata Polish AFV green which looks very light, but then my references show a very grass shade and a darker green, both in the same book. And neither look like this. Trying a bit of an experiment in free-handing it on the TKS's and it doesn't look too bad so far. I'm using the 'hi-flow' nozzle on my Aztek brush for the first time, so it's all new. Not too worried about what looks, in the photo, the slightly patchy green on the Wz.29 as there's still the brown to go on.
                  One concern is that the blu-tack might take the base sand off. As I was pushing the blu-tack into place, it was scraping clear
                  We'll see...
                  • Steve-the-Duck
                    • Jul 2020
                    • 1731
                    • Chris
                    • Medway Towns
                    Just found I've got scale plans of the TK-3, forerunner of the TKS - so that'll be a conversion coming. Probably a C2P tractor version
                    Perhaps even an interior with open hatches...
                    • Mini Me
                      • Jun 2018
                      • 10711
                      Looking forward to that Chris. Rick H.
                      • adt70hk
                        • Sep 2019
                        • 10426
                        Looking good Steve.
                        ATB.
                        • Steve-the-Duck
                          • Jul 2020
                          • 1731
                          • Chris
                          • Medway Towns
                          Quick update - I'm playing around with my airbrush. It's an Aztek job with different heads for different flow rates
                          The green was with the 'hi-flow', the brown with the 'medium flow'. Unless I've labelled them the wrong way round. Just needs a bit of touch up.
                          Haven't posted the Wz.29 as it needs a lot more work. the blu-tack didn't take off the base colour, but it did leave some odd shapes and edges
                            Did the airbrush came in a box with storage slots for the nozzles? If so, my solution may work for you: I’ve put them into those slots from biggest on the left to smallest on the right. This because I can never remember which colour is supposed to be which
                              • 18931
                              The grey one is the medium flow nozzle, but I can’t remember which colour is the hi flow Haven’t used mine for years as I find it too air hungry!
