Update.
It has been a few days since I last posted, and what an eventfull few days it has been - But I am not going to bore you to death with the fact that I have now had my second jab and have the badge of honour to prove it, there have been no side effects, side effects, side effects. And now you may call me "Two-Jabs..." much better than I have been called in the past.
So the last post dealt with the headlight guards, and pretty they look - but it was during the test fitting of the first headlight that one of them just vanished, so undeterred I used the second one and that decided to take flight as well. So! it was nose to the carpet, all around the room, all the kits under the bench came out, spiders wintering in the dark recesses were evicted in the search, then it came down to drastic measures, the hoover, first it was cleaned out and then the room was hoovered - nothing.... Replaced all the furniture and then I saw it, laying in the middle of the floor all twisted and bent out of shape :crying:......
Anyway two more were produced this time under strict regulations and of thinner wire, the lights were fixed in position, as was the horn and the other little bit???
I also decided to not use the rubber type gun mantlet cover, so used one as a master and made one from resin, which I destroyed trying to drill the hole for the barrel to a larger diameter, but the second one worked after some sanding and filing of the barrel, just where it fits into the hole on the mantlet cover..
And this is where I am today plus wheels and some track built, next is the engine decking...
Mike
Mike
