Beginning to think it's the m3 penthouse suite!
Rare Medium Tank M3 variant, from a MiniArt kit
I’ve managed to make myself start adding the rivets now:
[ATTACH=CONFIG]n[/ATTACH]
You can tell how much fun this job is by me alternating it with assembling track links :smiling3:
The rivets are all punched from 0.25 mm plastic card using an RP Toolz punch-and-die set, with an 0.7 mm punch designed for making domed rivets. You don’t need to buy a separate set for this if you already have a “flat” punch-and-die set — just order spare punches in the sizes you want. You need the ones that say “for Rivet maker”.
Some years ago, I reviewed AFV Club’s T48 track and wasn’t too impressed. Their main failing was that the track kept falling apart because the pins were too narrow for the holes in the end connectors. Somewhat unexpectedly, this T51 set is far better. The pins are, if anything, often a little oversize rather than under-. That is, the connectors sometimes won’t fit, but I’ve solved that every time so far by trying a different one. At least this track doesn’t fall apart when I pick it up.Comment
Like the Grant command tank that a photo was already posted of on page 1?Comment
I’ll give the clue that the big structure serves a definite purpose, but it’s not to house radiosComment
"Signor Whippy" armoured ice cream parlour & coffee bar for the Italian campaign ?
I'll be honest, I'm grasping at straws here....Comment
What make of stopping is that Mike? I always liked Tamiya filler, which is cellulose based, for the same reason. However it seems near impossible to get it at a reasonable price including postage so I’m looking for an alternative.Comment
Well,I`m stumped also!
Been viewing from the cheap seats,and did have a few ideas...... sadly though,the guesses so far have negated them!!:dizzy:
so i`ll just revert to type.........
"Is it Elton John Mark?.... sounds just like her!!"
Sorry,couldn`t resist!..... you have to be of a certain age,and remember Mark and Lard from the radio one comedy show in the late 90`s,early 2000`s!:tears-of-joy::tears-of-joy:
(They were a quality duo BTW!!)
AndyComment
AndyComment
