MS-1 (T-18)
  • Neo
    • May 2018
    • 526
    MS-1 (T-18)
    Greetings,friends! I need some rest after A13. I'd like to build something different. So I think this rare and very interesting tank will be very welcome.
    Here I am today near St. Petersburg with MS broken hull.
    [ATTACH]422618[/ATTACH]
    I have an early variant kit from Hobby Boss, outstanding resin kit with chassis and Masterclub tracks.
    [ATTACH]422615[/ATTACH]
    [ATTACH]422616[/ATTACH]
    [ATTACH]422617[/ATTACH]
    • 18884
    Looks like a Renault FT on steroids Neo. I’m sure you will make a fantastic job of it though.
      That’s pretty much what it was: the USSR decided to improve on the FT and the MS-1 was the result.
        • 15650
        Hi Artyom
        Looking forward to this.
        • Steve Jones
          • 6615
          You can't keep a good man down. Great project. I hate master club tracks. Hopefully they are not the metal ones???
          • adt70hk
            • Sep 2019
            • 10400
            Artyom
            Interesting choice and I think the first one I've been seen built on a forum.
            Slightly ashamed to say the first time I came across it was on World of Tanks, where it starts the Russian line if I remember correctly.
            As always I have every faith in your abilities.
            ATB.
            • Neo
              • May 2018
              • 526
              Hi,friends! Yes,it something different. Of course I have plans to build some Soviet pre-war tanks. Sometimes I get back to this topic. Indeed this tank is a deep modification of FT-17 by soviet engineers. First soviet serial tank.
              Masterclub cancelled produce resin track some time ago. All their new tracks are from metal. I hope this project will be interesting to me and for all of you.
              • Isitme
                • Nov 2020
                • 795
                Artyom,
                Be very carefull of the tracks they will be fragile unlike Fruil tracks, my M113 ones were a nightmare so resorted to using brass wire instead of the plastic pins which half the time did not fit.
                Mike.
                • Steve Jones
                  • 6615
                  Totally concur with Mike. I am just finishing off my C7P tracks and I changed the plastic pins to 0.4mm wire but again you have to be careful when fitting together so as not to bend each link.
                  • Mini Me
                    • Jun 2018
                    • 10711
                    This should be a snap Artyom..........not nearly as many rivets to do and it looks to be a bit smaller than the A 13. :thumb2: I'll stick with this and see how you do. Rick H.
                    • Neil Merryweather
                      • Dec 2018
                      • 5182
                      • London
                      looking forward to this Artyom
                      • Neo
                        • May 2018
                        • 526
                        I have some experience with those tracks. Thank you for advice. I usually change all thin pins by wire. Then I just glue a pin rivet in the end. This tank is very small. I think it could fit on A13 engine deck. Remember Japanese tankette TK on Sherman.
                        • Neo
                          • May 2018
                          • 526
                          First of all I've started to separate armour plates. I see not only Bronco forget to do this. And the most hard part and also interesting is lower hull armour plate. I need to improve it with putty in several stages.
                          [ATTACH]423670[/ATTACH]
                          [ATTACH]423671[/ATTACH]
                          [ATTACH]423672[/ATTACH]
                          [ATTACH]423673[/ATTACH]
                          [ATTACH]423674[/ATTACH]
                          [ATTACH]423675[/ATTACH]
                          • scottie3158
                            • 14198
                            • Holbeach
                            Artyom,
                            I'm in for another master class.
                              • 22769
                              Cracking start, just pulled up a chair
