Scotties Rolls Royce
  • JR
    • May 2015
    • 18273
    #211
    Slowly getting there a few plants added and a bit more weathering to the building. I'm not 100% happy with the result so far so if anyone has any suggestions on how to give it the finished look I would love to hear from you.
    I took the pictures in the sun so they are a bit washed out.
    [ATTACH=CONFIG]n1156976[/ATTACH]
    [ATTACH=CONFIG]n1156977[/ATTACH]
    cheers
    Scottie
    Paul, not that you need any advice, but I would start with a 400 grit sand paper over the walls to remove any out of scale lumps, then add a few cracks to the window frames and anywhere else where there is wood or damaged render, like around the area on the right lower section.Then I would apply some lighter shades of the render , cream, ivory white etc with down ward strokes with different size brushes. Once dry a very thinned black wash, and use a sponge or cloth to lighten some areas.
    Think the layout is great at that angle, esp like the greenery, well the nearly alive greenery .:smiling3::thumb2:
    • Isitme
      • Nov 2020
      • 795
      #212
      cheers
      Scottie
      Can you open a door I can feel the heat from here - that looks so good.
      Mike.
      • Mark1
        • Apr 2021
        • 4156
        #213
        Now John's mentioned it i guess a few cracks around the missing render would look good but either way it's a lovely piece of work.
        • scottie3158
          • 14202
          • Holbeach
          #214
          Cheers John, I will have a look at the things you mentioned. there is quite a bit of streaking but its quite subtle and can't be seen in the bright photos.
          Mike.
          Cheers Mike talking of doors I will need to add a latch or something.
          Cheers Mark I will have to revisit and have a look.
          • BigGreg
            • 2182
            #215
            Daaaaamn it's really coming along super cool....no warm...(sorry that was really a bad one).... :smiling5: :smiling5: :smiling5: :smiling5:
            • scottie3158
              • 14202
              • Holbeach
              #216
              cheers Greg but this is simple compared with your next project.
              • Mini Me
                • Jun 2018
                • 10711
                #217
                Perhaps some damaged pottery or some clutter just to bog it up a bit. :thinking: Rick H.
                • scottie3158
                  • 14202
                  • Holbeach
                  #218
                  Hi Rick,
                  I was thinking of some clutter I need to look at what I have or can make.
                  • scottie3158
                    • 14202
                    • Holbeach
                    #219
                    Taking on board the advice I have been given added a few streaks and a few more details. I decided not to smooth down the plaster as I actually like rightly or wrongly the rough uneven finish.
                    cheers
                    Scottie
                    • Mark1
                      • Apr 2021
                      • 4156
                      #220
                      Taking pictures out of the sun has made a good improvement, different tones stand out a lot better. Gonna look great with the roller in there.
                      • JR
                        • May 2015
                        • 18273
                        #221
                        Having seen some Eastern plastering just now on U Tube I think you are quite correct !
                        Agree with Mark about the new photos Paul, the tones do stand out.:thumb2::thumb2::thumb2::thumb2::thumb2:
                        • scottie3158
                          • 14202
                          • Holbeach
                          #222
                          Thanks Mark, I am fairly happy with it now.
                          • scottie3158
                            • 14202
                            • Holbeach
                            #223
                            Cheers John, I think this guy did some work for me once
                              • 15704
                              Hi Scottie
                              A real treat for the eyes. Coming on so well. The colouring gives a great sense of heat and dust.
                              • BigGreg
                                • 2182
                                #225
                                Getting better and better
