Scotties Rolls Royce
  • Mini Me
    • Jun 2018
    • 10711
    #46
    Keep it coming Scottie.....Mr. Jones must be beside himself with all the "rivetry" going on here. Rick H.
    • outrunner
      • Apr 2019
      • 2420
      #47
      Fantastic work again Scottie.
      Andy.
      • minitnkr
        Charter Rabble member
        • 7538
        • Dayton, OH USA
        #48
        You OWN this etch.
        • Isitme
          • Nov 2020
          • 795
          #49
          Scottie,
          Very impressive, looking forward to more.
          • scottie3158
            • 14201
            • Holbeach
            #50
            Originally posted by Steve-the-Duck
            Ooh, ooh - just watched David Fletcher's Tank Museum video, which has a shot of their RR with the turret off
            And our survey says yes
            Cheers Chris, I will go with the yes
            Very nice updates Paul.
            Thanks Lee
            Originally posted by Graeme C.
            Some nice upgrades there Paul, the open pistol port is a nice touch.
            Thanks given there is no interior I thought it would be a good way of opening it up without being able to see inside.
            Originally posted by GerryW
            Incredible work - did you make the hinges yourself?
            Hi Gerry, the hinge parts come as etch but the pin has to be added as do the rivets they are a little big but they are the smallest my punch set does.
            Rick, I have to do something to keep up with him.
            Andy.
            Andy.
            To kind
            Originally posted by minitnkr
            You OWN this etch.
            Thanks Paul.
            Originally posted by Isitme
            Scottie,
            Mike, just trying to keep up with you mate.
            • scottie3158
              • 14201
              • Holbeach
              #51
              Only a little more to show. the can was scratched as the kit one was very vague. The chest is part of the wood set in the etch set.
              side lights were added plus cables as were the head lamps. I had to adjust the radiator doors as I had opened them up to much and they fowled on the head lamps.
              I have noticed some seam lines on various parts and a nasty glue mark they will be addressed .
              cheers
              Scottie
              • JR
                • May 2015
                • 18273
                #52
                Bl**dy Nora Paul, that's some scratchery.
                Still it's what we've come to expect from you, and you don't disappoint.:thumb2::thumb2::thumb2::thumb2::thumb2 :
                  • 15697
                  Hi Scottie
                  Superb scratching. As John says we expect no less from you.
                  • adt70hk
                    • Sep 2019
                    • 10409
                    #54
                    Paul,
                    That is coming on very nicely indeed and as the others have said, some great scratch work on show.
                    ATB.
                    • RonGlass
                      • 801
                      #55
                      Very inspirational Paul, detaiing is amazing. For the tiny stuff, rivets, bolt heads on the steering nuckles, is that pewter sheet ? And do you use CA glue or ?
                      I've used tiny drops of gloss clear as adhesive with success...
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        #56
                        Stunning work every time Paul
                        • scottie3158
                          • 14201
                          • Holbeach
                          #57
                          Thank you John, still along way behind some on here.
                          Originally posted by Jim R
                          Hi Scottie
                          Cheers Jim, appreciate it.
                          Originally posted by adt70hk
                          Paul,
                          ATB.
                          Hi Andrew thanks fella.
                          Hi Ron yes it is pewter sheet and yes I use CA i have used gloss clear as well in the past it does work well.
                          Thank you Bob.
                          • scottie3158
                            • 14201
                            • Holbeach
                            #58
                            while having a tidy up at the school today I came upon these, and thought to my self they could make good cactus or if placed together even the trunks of palms. So next I will give them a soak in glycerene, and have a play.
                            Not alot done to the wagon but I have made a start on the rear storage area.
                            cheers
                            Scottie
                            • Isitme
                              • Nov 2020
                              • 795
                              #59
                              [ATTACH]427824[/ATTACH]
                              [ATTACH]427825[/ATTACH]
                              cheers
                              Scottie
                              No, they have got to be whats left of your loofah's..... Wonderfull work on the RR.
                              Mike
                              • scottie3158
                                • 14201
                                • Holbeach
                                #60
                                Mike
                                Mike I'm no gardener and I don't know what they are but they are about 4-5cm long so they could be ok for some desert scenes. Glad you like the RR.
