Hi everyone.
For my debut posting I'd like to give an account of my project to build the Takom Whippet as A220, captured by the Germans and restored to running condition as 'Repair Job 111' or 'Freikorps 53'.
Tankograd 1004, Beute-Tanks Vol 2, by Rainer Strasheim was the main inspiration, but 'Tank Encyclopedia-Whippet' and 'Landships Whippet Interior' provided a lot of extra information.
Following 'new ownership', the most obvious change is the German three colour camouflage; but there is more to it than that. Some parts, like the tow-cable hooks and the front track canvas support angle strips, are missing, and the stowage box mountings have been modified. I also plan to add a representation of the interior, and leave the door open.
A more significant 'finger print' is the set of angle iron reinforcing strips bolted to the ends of the track plates, both inside and out. This modification was carried out while in British service, and doesn't seem to have been common.
Views of both sides show a rather random arrangement, with different angles, lengths and number of bolts.
I modelled these using Evergreen 2mm angle strip, with the flange filed back to about 0.8mm. The bolt holes were drilled 0.6mm, before gluing to the kit parts, ( in case I made a mistake ). The holes were then re-drilled through the plates, and 0.6mm hex bolts ( from 'Prime Miniatures ) with heads thinned to about 0.5mm, were superglued in place.
The picture shows my progress so far
I shall complete the other side when fresh supplies of bolts arrive, then work through the assembly instructions for a while, before making arrangements for the interior structure.
