Hi I started by removed all the engine deck and track guard side details
[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
Pete.
Hi started with the turret as there not much to it.
Added tie-downs to the side, made up to to antenna masts, added a bit more detail to the barrel bore
[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
Fitted new front, headlights, tow shackle.
Fitted engine deck and some extra detail
Added a some more detail to the sprocket adjusters
Thank you for looking in.
Pete.
Hi I've tried to improve the look of the front sprockets by added some details.
Added track access hole added 1/35 track.
Added side hull details, air intake stacks and added some extra detail, exhaust pipes plus brace,
Pete.
WIP
Hi made up the support cables and anchor point, finished making up the tracks.
[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
Hi managed to get the hairy stick out and got the primer coat on
Thank you looking in this is now shelved lost interest .
Pete.
Hi have decided to finish this one off.
Hope you like it.
[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
Pete.
Great finish, esp like the spare track links on the rear track guard. Pete. Scratchery as your normal high standard, those sprocket cut outs are impressive. :thumb2::thumb2::thumb2:
Whats next ?
