Toon Churchill Wurlitzer and Ark 1
  • adt70hk
    • Sep 2019
    • 10408
    #16
    Yet again, great work Pete.
    ATB.
      WIP on the Ark1
      Repositioned rear sprockets by raising them up by 7mm.
      Blanked of turret ring.
      Started work on on rear engine deck and air intake.
      Cut tracks length and fitted.
      Started work on modifying the side track guards
      [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
        • 18901
        Up to the usual high standards I see Pete…..always fun to watch a skilled man at work!
          • 22770
          #19
          Outstanding work
          • scottie3158
            • 14201
            • Holbeach
            #20
            Pete,
            Loving the conversions, it takes a lot of skill and faith to remove so much plastic.
              Hi Tim thanks, where's this skilled man must get some tips.
                Originally posted by papa 695
                Outstanding work
                Thank you Ian to kind
                  Pete,
                  Cheers Paul, its nothing special at all.
                    WIP on the Wuritzer.
                    Not much progress today have run out of 0.5 white card :rolling: but did make the 4 headlight blackout hoods and the air intake cover's for the Wuritzer and start on its engine deck.
                    Pete.
                      Scratch built casement adding domed rivets, hex bolt heads and made side armour and started adding details.[ATTACH=CONFIG]n[/ATTACH]
                        • 22770
                        #26
                        Very nice work indeed
                          • 18901
                          This looks great Pete. Fantastic scratch and detail up work as always. Can’t help hearing “I do like to be beside the seaside” as I look at it though….it’s that mighty Wurlitzer connection…..you could always display it by having it appear out of the floor….with that playing as it rises up.
