Tamiya - Daimler Dingo MkII - 1/35 (1972)
  • dalej2014
    • Aug 2021
    • 507
    #46
    Back from Scotland, so a bit more progress on the build. Most of the fiddly bits are fitted now, apart from the rear view mirror. That's just begging to be knocked off, so will be left until last, along with aerials (if I can find something thin enough for them).
    I've done a couple of coats of buff to the Dingo, and started on the wheels with "German grey". It'll soon be time to put the wheels on, seal it with some varnish and do some decals...
    And the little Dingo:
    Once I've sealed it with varnish and put the decals on (something I always struggled with in the past!), I'll look to begin the process of weathering and colour modulation. Should be interesting, since I've never done it before! I think for this kit I'll keep it simple. Pin wash. Colour mod on panels. Maybe some lightening and highlighting. It'll either make the build, or completely ruin it. Fingers crossed
    • dalej2014
      • Aug 2021
      • 507
      #47
      Also just joined the MAFVA which seems a real bargain at the price. I'll contact my local branch (Suffolk) but expect I'll travel to some events in neighbouring counties too. Cambridgeshire - I'm looking at you!
      • adt70hk
        • Sep 2019
        • 10433
        #48
        Coming on nicely!!
        ATB.
        • dalej2014
          • Aug 2021
          • 507
          #49
          Originally posted by adt70hk
          Coming on nicely!!
          ATB.
          Thanks Andrew.
            • 15746
            Hi Dale
            Really coming on now Decals vary a great deal depending on the manufacturer so stick with it. Using a decal setting/softener can really help.
            • JR
              • May 2015
              • 18273
              #51
              Looking good Dale, just take your time. You'll soon get the hang of it.
                Thin (0.3 mm or so) spring steel wire works well. Just don’t buy it coiled up — you’ll never get the curve out, so buy it in straight pieces.
                • dalej2014
                  • Aug 2021
                  • 507
                  #53
                  Thanks all, appreciate the positivity, and the tips. I'll look for some fuse wire or similar. Cheers.
                    • 18932
                    Fuze wire will be too soft Dale. It will bend if you look at it fiercely. Try somewhere like Eileens emporium or your local hobby shop and get some straight nickel silver wire.
                      • 18932
                      Nice work on the build, by the way….I forgot to comment :flushed:
                      • dalej2014
                        • Aug 2021
                        • 507
                        #56
                        Thanks Tim. Looking at some 0.3mm wire for jewellery making in black. Looks good for the job. A spool should last a lifetime
                          • 18932
                          If it’s on a spool you will have trouble straightening it…try here Dale
                          Vespa188 merupakan Situs Slot Terpercaya, Resmi dan Gacor No 1 Indonesia. Minimal deposit untuk bermain adalah 20 ribu dengan minimal putaran 200 perak.
                          • dalej2014
                            • Aug 2021
                            • 507
                            #58
                            Thanks Tim. A veritable emporium indeed. My poor wallet. I'm not looking any further than wire... Well, maybe just a peek?
                            • dalej2014
                              • Aug 2021
                              • 507
                              #59
                              Well, it felt really wrong to gloss varnish an AFV, but trusting in the process, advice, Youtube etc. that's what I've done. I used the Mig 2053 "Lucky" gloss varnish. Nice and thin so won't obscure surface details. Went on in a matter of minutes with a big brush. Now I have to wait 24 hours for it to completely cure, although it was touch dry in 10 mins,, then it's out with the oils, pigments and pencils:
                              • Mark1
                                • Apr 2021
                                • 4156
                                #60
                                Coming on nicely :thumb2:
                                I usually put my pigment,dirt/rust etc on after final matt coat mixed with thinned matt,not sure if that's right or wrong but have heard that putting the final matt over the top can obscure the colours quite a bit so I never chanced it.
