Tamiya - Daimler Dingo MkII - 1/35 (1972)
  • Mark1
    • Apr 2021
    • 4156
    #76
    Looks alright for a first go mate :thumb2: some of my mud and rust attempts looked like the vehicle was driven at high speed through a black forest gateau !
    • Airborne01
      • Mar 2021
      • 4038
      • Steve
      • Essex
      #77
      I think some of mine still do Mark LOL!
      • Mark1
        • Apr 2021
        • 4156
        #78
        Most of mine still look like the weathering's been applied with a catapult. :smiling5:
        • Airborne01
          • Mar 2021
          • 4038
          • Steve
          • Essex
          #79
          And your point is .... ?
          • adt70hk
            • Sep 2019
            • 10445
            #80
            Dale
            Coming on very nicely indeed. Very well done so far.
              • 18958
              Looking good Dale.
              • rtfoe
                • 9125
                #82
                Dale, if you haven't purchased the wire for aerials try metal guitar strings. The smallest nos. 1 or 2. They're cheap and stiff. You'll need real wire cutters or you'll destroy your nippers trying to cut them. They're coiled but spring out when released.
                Richard.
                • dalej2014
                  • Aug 2021
                  • 507
                  #83
                  Richard.
                  Thank you. I was able to buy some from a local model railway shop. It's an Aladdin's cave of materials for dioramas. I also like that I'm supporting local business buying there. Appreciate the thought though, cheers.
                    • 18958
                    Richard.
                    Guitar wire is sold in โ€œthouโ€ sizes, ie 008 thou, 009 thou etc. upwards. This is thousandths of an inch. Working on a good rule of thumb, 040 thou is about 1mm, so a 010 thou string is about 0.25 mm. Donโ€™t get the coated ones, just normal slinkies will do you. You also donโ€™t need the wound stringsโ€ฆ..
                    Nickel silver straight pin wire is also readily available in sizes from about 0.3mm in 0.1 mm increments. It is also stiff, straight, and a lot easier to cutโ€ฆ
                    • dalej2014
                      • Aug 2021
                      • 507
                      #85
                      Dialled back the chipping a bit, as it seemed a bit much, and added some "rust" using Winton Burnt Sienna. I have to say the shade is spot on, and I like the effect. I think this part of the weathering is done, so time to lock it in with a varnish coat. Moving on tomorrow to some buff filters to start lightening, then adding some pigment "sand" in some nooks and crannies. Oh, wheels will need a coat of powder too:
                      Note to self - add some more weathering in the interior.
                        • 15818
                        Hi Dale
                        Looking good. Each effect is changed by the next layer/process. Your buff filter and then pigments will tie things together.
                        • dalej2014
                          • Aug 2021
                          • 507
                          #87
                          Originally posted by Jim R
                          Hi Dale
                          Thanks Jim. Appreciate that
                          • Mark1
                            • Apr 2021
                            • 4156
                            #88
                            That's coming along nicely :thumb2:
                            • dalej2014
                              • Aug 2021
                              • 507
                              #89
                              Thank you Mark
                                • 18958
                                Coming on nicely Dale.
