Who? Who? Ron's 251/20 UHU , that's who !
Ron, I'll be honest, I totally missed this !
Nice looking kit and you're really bringing it to life.
Love the fenders.Comment
:sad-face::rolling:Plowing along , here is the searchlight in progress. Need to paint the filter lens a black-red to continue with this build. Have quite possibly ruined my AB from forgetting to clean after last use. May be a while before I can shoehorn that expense into my present budget, will see....Comment
I would first try disassembling it as far as possible to try and clean everything — if it is ruined, then you have nothing to lose, while if it’s just stuck then it will save you having to buy a new one.Comment
I’m sure that cellulose thinners will remove all paint deposits that are in there Ron. As Jakko says, strip it right down, then soak all the parts in cellulose thinners for a couple of days….scrub it, rinse it, have a really good look, then soak again if needed. Repeat this until it is clean. The worst you may need to do is replace a couple of seals and perhaps the nozzle. While you are doing all this, remind yourself why you are having to do it rather than build models….bet you don’t leave it againComment
Looking good Ron
Did you have to add your own extension strips to the rear of the top half of the hull to get it to fit together with the rear plate?
As for the airbrush, I've used a sonic cleaner successfully in the past to save it. They are not expensive.
Best of luck
LosComment
Ron,
Lovely work on the search light I painted my lens with a dark black/red on the reverse side of the lens and it looked ok. I agree with the others a good strip down and soak should work and I am talking about the airbrush.Comment
Thanks Guys for all of your replies, have had the nozzle soaking for a couple of days. Today I'm on the mend from a particularly obnoxious 24- (48- ?) -hour bout with a head cold, spent the whole of yesterday curled up in a fetal position wrapped up in a cocoon of fleecy throws.
But Scottie, thanks Bro, your quip actually elicited a chuckle from me during the worst. And that was sorely needed :face-with-head-bandage::smiling5:
PS later today I feel up to trying out the AB , I am hopeful after all you guy's input, Thanks !Comment
