Mike and Jakko kindly sent me some advice on assembling the suspension and running gear. There are a lot of bits that all need to be in the right place at the right time but it went to well without any problems. So thank you guys. this is the end result .
[ATTACH=CONFIG]n1157649[/ATTACH]
having fun so far.
Scottie
All facing the wrong way!!!!!
Just kidding :tongue-out3:
Looking good so far, the hard work is done.
Mike.
Given there a lot more cleverer people on here than me. How do I sort on the net to find a particular vehicle I have tried the tanks serial number and unit but can't find anything specific.
As you know I'm not normally to worried about getting things 100% right but the kit has a choice of rivets and bolts and other small parts, and I would like to use the right ones if I can. the instuctions give the choices but not as to which vehicle.
Thanks in advance.
Confused from ward 12.
I think you’ll probably have to go at it the other way Scottie….find a photo of a Churchill you like, then work through the options selecting those that are appropriate ….
