Churchill AVRE Mk. lll
  • Mini Me
    • Jun 2018
    • 10711
    #106
    Where'd you hide the "Shrinking Ray Gun" Mr. Scottie.....the committee is bound to find you out sooner or later :tongue-out3: :tongue-out2::thinking: Rick H.
    ps. superb attention to detail Sir.
    • scottie3158
      • 14253
      • Holbeach
      #107
      Originally posted by Mark1
      Lovely detail work :thumb2:
      Thank you Mark.
      Originally posted by outrunner
      Marvelous work!
      Andy.
      Cheers Andy
      Originally posted by Jakko
      If you look at the strip that’s over the hammer, but below the shovel, it looks just like very shallow U-profile. I thought that was intentional, so I wondered how you have managed to bend that so neatly into having two upturned edges :smiling3:
      Jakko, looks like a happy accident. It is just the burr from cutting the strip so will be worth remembering if this look is required.
      Its those hinges showing the knuckle like that, extreme scratchery Paul .
      Thank you John, I always use 0.3 wire and not the 0.5 the instructions call for I find it makes a stronger joint.
      Originally posted by minitnkr
      Amazing.
      Many thanks Paul.
      Cheers Rick a shrink ray, that would certainly make things easier.
      • scottie3158
        • 14253
        • Holbeach
        #108
        The can holders the other side have been done, one has been left empty just to be different,
        Earlier in the instructions it advised to drill a hole either side in the track guards at the rear. These are to mount what I presume are spare suspension units. I have since decided after trying them in place that I will leave them off as most reference pics don't show them fitted. So I have cut and glued two plugs will will be dressed when the glue has dried.
          They’re not spare but were used on some AVREs for engineering-related work, essentially as rollers, off the top of my head. I think they appear on models more than on the real thing, though I don’t recall the exact function off the top of my head.
          • scottie3158
            • 14253
            • Holbeach
            #110
            The huIl builds is pretty much done now. The next stage of the build is the mortar. This is a nicely detailed part of the kit and went together well.
            Next the turret was assembled and the surface prepped for the addition of the details.
            cheers
            Scottie
            • scottie3158
              • 14253
              • Holbeach
              #111
              The turret bin is done there was an etch option but cant see the point so used the kit part with etch fittings also added some 0.5 rivets to the lid. I will add it to the turret later.
              The loaders hatch has also been added along with the catches.
              cheers
              Scottie
              • Graeme C.
                • 1613
                • Graeme
                • UK
                #112
                Very tidy work Paul, the etch is very nice.
                • scottie3158
                  • 14253
                  • Holbeach
                  #113
                  Cheers Graeme
                  • Jack L
                    • Jul 2018
                    • 1277
                    • Cheltenham
                    #114
                    Very nice Paul…those hinges on the loaders hatch look like they might work? :flushed:
                    • adt70hk
                      • Sep 2019
                      • 10439
                      #115
                      Paul
                      That is coming on very nicely indeed. As Jack said, the hinges on the loafers hatch look workable. Very impressive
                        • 15817
                        Hi Scottie
                        The first thing I notice is just how neat the pe details are. Great skill and attention to the little things which lift a model to the next level.
                        Carry on Sir - excellent stuff.
                          Originally posted by Jim R
                          Hi Scottie
                          Jim I think there's some sort of magnetic thing going on here
                            You never fail to amaze Paul. The epitome of modelling skill.
                            • Si Benson
                              • 3572
                              #119
                              Ver nice Scottie :thumb2:
                              • scottie3158
                                • 14253
                                • Holbeach
                                #120
                                Jack thanks mate they do work but I put a small amount of CA on them to keep them from moving and extra strength.
                                Originally posted by adt70hk
                                Paul
                                Cheers Andrew, as I said to Jack they do work when assembled but are glued for strength.
                                Hi Scottie
                                Cheers Jim, very kind of you. I do like PE but only where it can actually improve the look not just for the sake of using it.
                                Thanks Si nice of you to say.
