Heng Long 1/16th tanks
  • eddiesolo
    • Jul 2013
    • 11193
    #31
    Originally posted by Ancientmariner
    That looks amazing!!! How hard is it to scan/design models to print? Is that solid?
    Hi James, there are various software programs and downloads you can get. I got this from a guy who got it from somebody else, but he bodged it and left it.
    3D prints are normally like a honeycomb, so strong and light but they can shear/shatter if dropped and are a pain to dril, you have to go slow. Again it depends on the size, quality of the printer then software that works with your printer and then using a good quality filament. Also the print time as you will need to leave it running all night for certain pieces.
    • eddiesolo
      • Jul 2013
      • 11193
      #32
      Oh and what scale is that?
      This is 1/16 and will be RC.
      • Ancientmariner
        • Feb 2018
        • 859
        #33
        Looks great! Might have to requisition a 3D printer next at now......
        • adt70hk
          • Sep 2019
          • 10409
          #34
          I am not sure whether to put another line on the right side, where it comes down the turret. It goes under across the back but from the side looks like a lines missing if you know what I mean?
          I think another set of lines would look better.
          • Ancientmariner
            • Feb 2018
            • 859
            #35
            So have put tracks on the KT and started chipping raised edges. Something I haven't done before but coming out ok. Not sure how it will look when I spray white over it all.
            Anyway found chipping good but it's hard to get the point where's it's enough and not too much....
            Tried to show where the wire has been dragged across and scuffed the paint. Pondering putting brown in to make it look rusted in parts.
ID:	1163734Click image for larger version
ID:	1163735Click image for larger version
ID:	1163736Click image for larger version
            • adt70hk
              • Sep 2019
              • 10409
              #36
              I'm still learning in the chipping front too. I adopt the 'less is more' approach and when I think I could carry on and do a bit more, stop and put it to one side for a few hours. It's easy enough to add more but virtually impossible to undo....
              Keep up the great work.
              • Ancientmariner
                • Feb 2018
                • 859
                #37
                I know what you mean. I am trying to envisage where the wires would scrape the paint and also where boots and tools getting on and off the tank would do the same.
                As for the challenger not sure it's worth it with the light surface colour or maybe chip with red oxide?
                • adt70hk
                  • Sep 2019
                  • 10409
                  #38
                  James
                  Sorry can't help on that front. I know even less about modern armour than I do WW2 stuff.
                  Perhaps one of the others will know.
                  ATB.
                  • eddiesolo
                    • Jul 2013
                    • 11193
                    #39
                    Chipping can be awkward, you have to scale it and add it where it needs more or less. I have done chipping, used the salt method, liquid latex masking and the hairspray method. All have good and bad points.
                    The salt method is the easiest, drop your water on and sprinkle some fine salt then spray your top coat, use a stiff toothbrush to remove. Problem is for small detail areas, it can be problematic as you get clumping. A bonus to this method is that the salt helps to scour the surface and dull the paintwork giving that dull worn weathered look.
                    Liquid latex mask is handy but again it clumps and I found it unwieldy for delicate work. Slap on, let it dry and do your top coat then scrub the latex off, can be time consuming as it sticks all over and takes a fair bit of cleaning.
                    The Hairspray method is the best but you have a few steps to do. Your base/primer coat or weathering coat, then apply a varnish coat to protect the undercoat, then apply your hairspray (canned isn't always the best, you are better getting either a product ready made or decant some for use in your hairbrush but use quickly. Apply your top coat and then use a small stiff brush and water to dab away at the areas you have got the hairspray, it will come away with the paint, leaving the undercoat behind. When done, make sure you use a matt varnish to seal the model. I may have gotten the order wrong on this as it isn't something I use now and haven't done in a long time.
                    Also. wear is a important factor to look for, most tanks paintwork is pretty tough, it has to be, but you will get wear from hobnailed boots up and done, especially near hatches. Scrapes from foliage brickwork, hatche edges from closing and bringing in ammo, shells.
                    I also use graphite pencils to add a metallic wear sheen to top edges, hatches, you can add some and use your finger to smear and wear pattern. You just get a hint of metallic wear. Also, a black oil wash-oil paint and white thinners apply with a brush and use a makeup wedge sponge to dab, this will tone down the paintwork and make it look dirty.
                    This is my 1/35 'TANK OVERHAUL' dio using the liquid latex method. Red oxide, latex and then grey primer.
                    The 1/16 Tiger wear was all done by hand by scratching the surface with a very small screwdriver, never again as it took forever.
                    • Ancientmariner
                      • Feb 2018
                      • 859
                      #40
                      Love the rusting on that one, that is amazing!
                      It's too late for most of those methods now as I have already painted them. Will give the rusting a go though!
                      • eddiesolo
                        • Jul 2013
                        • 11193
                        #41
                        You
                        You can still use a graphite pencil, I have a selection, or even a normal pencil to do accents on hatches and rims etc. Also, you can still use the oil paint technique and the rusting even with the paint job done as these are final weathering finishes.
                        The rusting is just pigments, old rust, new rust etc and a pigment fixer but I use thinners. Use toothpicks, micro brushes and sponges to apply the rust. Like any model, if handling or using it is always best to add a matt clear coat after detailing, this does tone the rust done slightly so, if you go this route make the rust a tad lighter.
                        This is a knocked out 1/16 Tiger with weathering, rust and smoke effects.
                        • Isitme
                          • Nov 2020
                          • 795
                          #42
                          James,
                          Give the Challenger a wash with brown oil paint (Burnt Umber) this will tone down the desert colour. Too late now but you could have added non-slip texture to the hull and turret using ChinChilla sand which is a very fine sand like that used in egg timers. That aside both models look the part - well done. Mike.
                          • Ancientmariner
                            • Feb 2018
                            • 859
                            #43
                            So just watched a cracking video on tank tracks and weathering them.
                            Looking at the KT the tracks need to come back off and be weathered as they detract from the look of the tank I think.
                            • Ancientmariner
                              • Feb 2018
                              • 859
                              #44
                              So redone the tracks, not 100% but a lot better than they were I think.
ID:	1163946Click image for larger version
                              • eddiesolo
                                • Jul 2013
                                • 11193
                                #45
                                Those tracks look great James, add depth to the model. See loads of RC tanks with just silver or black tracks, the weather the body but leave the tracks. Even with running them and the scuffs etc it all adds to the look. Top work.
