AFV Club FV107 Scimitar CVR/T Falklands era
  • wasdale32
    • 1116
    • Mark
    Finally made a start on this as part of a club "Falklands 40" build thread.
    AFV Club Scimitar - the kit is for a late (Bosnia/Gulf) era vehicle but I'm using SMM resin and Fruil tracks to backdate to a Falklands era vehicle:
ID:	1159997Click image for larger version
  • wasdale32
    • 1116
    • Mark
    Mandatory sprue shots ...
ID:	1160005Click image for larger version
ID:	1160006Click image for larger version
ID:	1160007Click image for larger version
      • 22788
      Looking forward to seeing this, I used to play with these, and the Scorpion.
      • wasdale32
        • 1116
        • Mark
        First I had to replace the hinged transmission cover with the SMM bolted version
ID:	1160009Click image for larger version
        • wasdale32
          • 1116
          • Mark
          Opened the replacement "early" suspension and stalled ... one piece missing and one piece duplicated - I emailed Michael at SMM and he's sending me a replacement (excellent service)
          • wasdale32
            • 1116
            • Mark
            Decided to fill in some time by doing the crew (Accurate Armour) figures... Dunno if I've done them justice - the close ups pick out every little error!
              I’ve always liked CVR(T)s, and these are quite good kits (for those interested, the Revell ones are just reboxes of the AFV Club ones). Good plan to replace the tracks, though — the single-piece, soft plastic ones you get in the kit look thin and are so short they’re under a lot of tension when they’re around the wheels.
              Also: how long ago did you buy this kit, then?
              • adt70hk
                • Sep 2019
                • 10445
                Great work so far. Love the figures in particular!!
                ATB
                • wasdale32
                  • 1116
                  • Mark
                  Also: how long ago did you buy this kit, then? :smiling3:
                  I grabbed the kit in a local hobby store second hand pile about 3 years ago - cost about £15 if I remember correctly - picked up the other bits over the intervening time.
                  I might try to find a Revell Scorpion to go with the Scimitar.
                  • Jon Heptonstall
                    • 1704
                    It's a great model especially with the SMM parts.Did you get the etched track guards as well? Makes a big difference.
                    Also I can't tell whether the AA crew are wearing the early Dan Dare helmets or the more modern ones.Hornet do a set of heads with Dan Dare helmets if you need them.
                    Jon.
                      Then they clearly had it for a long time (Look at the sticker on the box.)
                      • wasdale32
                        • 1116
                        • Mark
                        Jon.
                        They're wearing the 1970's style helmets like these and early-ish combats with the smaller pockets. One has the old style fur lined cap but I've painted it as a private purchase
                        • wasdale32
                          • 1116
                          • Mark
                          Then they clearly had it for a long time :smiling3: (Look at the sticker on the box.)
                          It was a lucky find as it even includes the limited edition resin figure
