Cruising around in my A9 CS
  • scottie3158
    • 14201
    • Holbeach
    #16
    Well managed to cut some plastic yesterday and today. The lower hull has been started it has some basic details inside and has had a coat of silver. I wont be doing much as not much will be seen. As I said earlier the instructions show a lot more inside than is actually included.
    The front idlers are a lovely bit of engineering made up of 5 parts and some punched bolts.
    The four suspension units again are beautifully detailed. The kit had nicely moulded springs that actually worked but were so fragile I managed to snap 2. I modified the parts and used a couple of springs from the spares box. It all actually works and will allow some movement if being shown on uneven ground. One mistake I made was to attach the wheels I should have left them off for painting.
    cheers Scottie
    • rtfoe
      • 9076
      #17
      The Brits just can't keep it simple couldn't they but its got character.
      Is there room for any additional improvements Scottie?:smiling2:
      • scottie3158
        • 14201
        • Holbeach
        #18
        Not sure yet Richard, I am not going to do anything inside and out side is already fairly well done but I'm sure I will find something to do.
        • Steve Jones
          • 6615
          #19
          Nice to see you got springs in your kit. I had to make my own. LOL
          • scottie3158
            • 14201
            • Holbeach
            #20
            Steve they didn't come with the kit. There were plastic ones but they were really brittle and I broke two so I found these in my odds and sods box.
            • Steve Jones
              • 6615
              #21
              Nice!!
                • 18901
                Looking good already, and the Scottie touches are lifting what looks like a very good kit higher still…..
                  • 15681
                  Hi Scottie
                  As Tim says we are already seeing "Scottie touches" and that means a great model in the making. Glad the springs are sorted. Models do look good based on uneven ground - somehow more interesting.
                  • Graeme C.
                    • 1604
                    • Graeme
                    • UK
                    #24
                    Interesting beast Paul, got the Bronco version in the stash, be interesting to see how different they are.
                      • 22770
                      #25
                      Cracking start, even though Bob as took all the cake.
                      • Allen Dewire
                        • 4741
                        • Allen
                        • Bamberg
                        #26
                        Off to a great start here Paul and it looks like a fine kit to do your magic on. I know you will, but there are 2 things that are worrying me a bit..........
                        1. This great build will end up in a feeding frenzy with crumbs all over your work bench and a mess on the floor...............
                        2. Your seating Jim R next to the chocco bisquits worries me most. We don't want to turn our Jimbo into a Jumbo now would we????.........
                        Keep up the fine work Bro...
                        Allen (Ret.)
                        • scottie3158
                          • 14201
                          • Holbeach
                          #27
                          Nice!!
                          cheers Steve.
                          Thanks Tim, and there was me thinking I would do this one out of the box.
                          Originally posted by Jim R
                          Hi Scottie
                          Jim, the kit came with plastic springs but they were incredibly fragile and I snapped two.
                          Steve built the Bronco version if mine turns out a fraction as well I will be well happy.
                          Ian, Bob has been fitted with boxing gloves to slow him down a bit.
                          Allen (Ret.)
                          Allen, given the state of my bench crumbs won't even show and I have another pair of boxing gloves if required to fit JIm.
                          • scottie3158
                            • 14201
                            • Holbeach
                            #28
                            Grabbed a little bench time today. I replaced the kit deck handle with a copper wire replacement and added some punched rivet detail.
                            having looked at the picture I'm afraid the plastic hinge detail will have to go I will make some replacements.
                            Next I decide to have one of the MG turrets hatches open the other will be closed just for a bit of interest. It is nicely detailed. One thing I do know I wouldn't fancy spending any time in one.
                            cheers
                            Scottie
                            • scottie3158
                              • 14201
                              • Holbeach
                              #29
                              A little bit of bench time not a lot done as they have been quite fiddly. I removed the kit hinges and replaced them using some PE from the spares box. The exhaust was quite difficult with multiple bits of PE. I also added some bandage around the exhaust from glasses lens cloth. The mesh over the exhaust will be added when it has been painted.
                              next on to the fenders. I removed the moulded side light cables and added replacements from copper wire, with cable clamps made from foil and punched rivets.
                              cheers
                              Scottie
                                • 18901
                                Excellent scratch work there Scottie. Bit of a masterclass developing I think.
