Cruising around in my A9 CS
Richard, that is extremely kind of you but I am along way of that yet but hopefully I am improving.Comment
Thanks Tim, very kind of you.
Ron trust me I am still learning myself. The only way is to give it a go if you get stuck just shout out I and the others will only be to willing to help or PM me. There are some useful demos on U tube as well.
Thanks Paul, back when I discovered the MM website you were very helpful with sharing advice for better CA glue application control. That and me finally recently using some CA debonder for cleanup were real game-changers for me. And John Race clueing me in on labeling my multitudes of kit sprues (Thank You so much Obi-Wan John !! ). Sure has made this hobby so much more enjoyable.
Thanks Lee appreciate it.Comment
Some more tweaks. Added a handle to the jack, not sure if it had one but having used a few of these they always had one as they are heavy to carry. Then a strap was made from foil.
next the wiring for the horn, again a bit of guess work so more for effect than accuracy.
Work started on the main gun and mantlet, it is a nicely detailed assembly unfortunately most of it won't be seen. So it just received a quick coat of silver and a oil wash, with a few details picked out.
cheers
ScottieComment
Evening Buddy,
Looking really nice and I knew you couldn't just build it without adding some nice tweaks to make it even better. You're so right about the weight of the jack and a handle would definitely help carrying that puppy around. Is there a bar to pump it up included in the kit?
The gun is nicely detailed too. Almost a shame you won't see it with the turret closed up.........Drive on Bro!!!
Allen (Ret.)Life's to short to be a sheep...Comment
