Merkava Mk3D Late LIC - 1/35
  • MAK2020
    • Sep 2021
    • 210
    Kit from Meng. Fine detailed ....
    If someone see any error, please report to me:smiling3:
    I am not sure about antennas, how many in real life, and in which positions. Is there reason for positioning and/or type of antenna.
  • scottie3158
    • 14202
    • Holbeach
    A great finish on the anti slip. What is the large road wheel for?
    • MAK2020
      • Sep 2021
      • 210
      Large road wheel is masking cover for spraying, that i made on my lathe
      Anti slip is cheep sharpening stone crushed on grain size that match Merkavas antislip, and glued up.
      • scottie3158
        • 14202
        • Holbeach
        Two great ideas.
          It probably has to do with whether the tank is a command tank or not; whether it needs to talk to infantry, aircraft, or whatever; maybe some antennas are dummies (not actually connected to a radio); and more. I would just copy a photo of a real tank to make sure I got it right
          • MAK2020
            • Sep 2021
            • 210
            Originally posted by Jakko
            It probably has to do with whether the tank is a command tank or not; whether it needs to talk to infantry, aircraft, or whatever; maybe some antennas are dummies (not actually connected to a radio); and more. I would just copy a photo of a real tank to make sure I got it right :smiling3:
            Answer like that somebody asked me . But .... i am curious.
            • minitnkr
              Charter Rabble member
              • 7541
              • Dayton, OH USA
              As can be seen most often two white whip & a couple stumps (likely SAT, cell or sensor). Company/Battalion/Division HQ/staff would likely have more.
              Photo for reference only.
              • Isitme
                • Nov 2020
                • 795
                Nice to see a Merkava build.
                I like the non slip which on the real vehicles is also on the turret, which can be a pain to add, loads of masking and cleaning up. Normal antennae layout is as depicted in the kit and as you have it on your build. The thickest one is on the right behind the Cmdrs cupola. These antennaes can also be tied down to the rear with the fastening on the rear corners of the turret basket.
                If you plan on more IDF vehicles, a good source of reference are the excellent publications by Desert Eagle Publishing with the main author being Michael Mass.
                Mike.
                • Mickc1440
                  • 4779
                  I've just finished a 1/35 scale one, lots of antenna mounts but in a lot of the pics I looked at 3 seems to be the average so that's what I went with
