Fine Molds Type 3 Chi-Nu, 1:35
    The Type 3 Medium Tank Chi-Nu (三式中戦車 チヌ, San-shiki chū-sensha Chi-nu, meaning “Imperial Year 2603 Medium tank Model 10”) was one of the last tank types produced by Japan in the Second World War, essentially an improved Type 97 Chi-Ha with a larger turret mounting a bigger gun, a 75 mm to cope with Allied tanks. It didn’t actually see combat service, as all were kept on the Japanese home islands to defend against the expected Allied invasion.
    Fine Molds has a kit of this tank, which I bought second-hand some months ago and which I now intend to build. Here’s the box front:
    [ATTACH]437303[/ATTACH]
    It includes instructions as well as a four-page pamphlet with what I assume to be information about the tank, but as it’s all in Japanese, I can’t read it. I might give it a go with Google Translate at some point, though
    [ATTACH]437304[/ATTACH]
    The instructions are mostly in Japanese, but have shorter English bits where important, like for the colours. It leaves me with the strong feeling that Fine Molds consider Japan their primary market, though.
    Inside the box:
    [ATTACH]437305[/ATTACH]
    And shots of the contents:
    [ATTACH]437306[/ATTACH][ATTACH]437307[/ATTACH]
    I also bought some additional things for this kit:
    [ATTACH]437308[/ATTACH]
    The first-ever set of Friul tracks I’ll ever build, because they’re one of two options for replacements for the soft-plastic ones in the kit. Since the tracks on all these Japanese tanks were both dead and slack, single-link tracks are almost a necessity, I think. Also a set of Mr. Hobby Japanese colours, to get the colours right.
    The turned gun barrel was very cheap, which is mainly why I bought it when ordering something else. However, somebody made a mistake somewhere:
    [ATTACH]437309[/ATTACH]
    This is clearly not the barrel for this type of tank … So, obviously, I won’t be using it
    Generally, I think I’ll be building this straight from the box. The parts look very good and well-detailed, so there’s no need for major detailing etc. other than the tracks, so this should hopefully be another quick build
  • adt70hk
    • Sep 2019
    • 10409
    Interesting one Jakko. I think I saw Night Shift do a Chi Nu, minus the barrel IIRC.
    Shame about the metal barrel. On the barrel front, i'm sure all the pictures I've seen show a small muzzle brake fitted. Is there one in the box?
    ATB
      It does, don’t worry I’ll just use the plastic barrel — I normally would have anyway, but for the €3.50 this barrel cost I decided to buy it. Not sure what exactly went wrong, though. Is it the wrong sticker on the bag, or is it intended for some other Type 3 Chi-Nu that I’m not aware of? I assumed the former, but a bit of quick research reveals that there is also this kit:
      [ATTACH]437367[/ATTACH]
      Looks like the gun is for that, not for my variant of the tank. It doesn’t look like the required parts for this version are included in my kit, though, so I’ll just keep the barrel in case I ever want to build this one too.
        • 15704
        Hi Jakko
        An interesting choice. Many swear by Friul tracks so hopefully you'll like them. Definitely looks like the barrel fits the other version.
        • Steve Jones
          • 6615
          Initially the Chi Nu had the shorter Type 95 field artillery gun/barrel. Later the armament was strengthened and the longer Type 90 field artillery gun/barrel was used. However the longer barrel wasn't very reliable so the shorter barrel was the primary barrel used. I don't have figures of how many short barrel compared to long barrel Chi Nu's were made but the longer barrel was a lot less. Which begs the question why are RB Model and Fine Molds marketing a long barrel??
            I’m still wondering if I’ll swear by or at them
            That’s obviously the version I have, with the obvious cradle below the barrel.
            My guess is that Fine Molds simply decided to release every variant of the Type 97 chassis they could. As it’s a simple parts-swap for the gun, making both makes sense. I maintain that I would rather see one kit with both options, though, but it seems some manufacturers don’t think like that.
              The basic shapes of the upper and lower hull are easy enough to put together:
              [ATTACH]437432[/ATTACH]
              This being a Japanese kit, making comparisons to Tamiya is almost inevitable, I suppose. The first thing to note, then, is that this model is clearly not intended for motorisation — hurrah! Second, that sponson bottoms are provided, even if they need some filler at the front:
              [ATTACH]437433[/ATTACH]
              Talking of filler, one issue I noted is sink marks in several of the parts, like here on the suspension arms:
              [ATTACH]437434[/ATTACH]
              This needs filling on the smaller pair at least, which isn’t all that simple with that fine line around the circumference of the hub. But better to lose that than to have a whopping great sink mark on show. The larger ones show a bit of a depression, but it’s not very noticeable and they will be out of sight behind roadwheels, so no need to fill them.
              Each of the inner wheel hubs also has a sink mark, but those will be out of sight, so I won’t bother filling them either. (In fact I’m already wondering why I bothered to glue them to the wheels at all )
              • Isitme
                • Nov 2020
                • 795
                [ATTACH=CONFIG]n[/ATTACH]
                Each of the inner wheel hubs also has a sink mark, but those will be out of sight, so I won’t bother filling them either. (In fact I’m already wondering why I bothered to glue them to the wheels at all :smiling3
                You could always fill in the 'dimples' sand smooth and then punch out the rims from 10thou card using two different punch sizes.
                  Not a method that had occurred to me, but I’ll keep it in mind for future models that have similar problems — thanks
                    • 18907
                    Looks like it may give you a few interesting moments Jakko. Unusual subject though…..
                      It’s quite a good kit, to be honest. The biggest problem is these kinds of sink marks on many of the thicker parts, as well as some minor flash. The fit is good, the moulding is sharp (other than those problems I mentioned) and the detail is pretty good for a kit of around 20+ years old (as the basic parts are). I’d say it’s about Tamiya quality without the Tamiya drawbacks of moulded-on grab handles, open sponson bottoms, motorisation features and stuff like that.
                        Construction is now finished, as far as possible before painting that is:
                        [ATTACH]438493[/ATTACH][ATTACH]438494[/ATTACH]
                        I’m leaving off the wheels, suspension arms, mufflers, commander’s hatch and a few other parts so I can actually get paint onto and underneath them. Well, and I still need to assemble the tracks, I’ve half cleaned up the links for one of the two so far …
                          • 18907
                          Nice to see this making progress Jakko. It almost looks a little toon like, probably the large turret :smiling2:
                            Yes, I also thought the turret looks rather big. Bigger than I had expected from the box art and photos, certainly.
                              Here’s what I have built, all the other parts are still on the sprue for painting:
                              [ATTACH]438633[/ATTACH]
                              I also built a little jig to hold about ten track links for assembly:
                              [ATTACH]438632[/ATTACH]
                              I put together five links without, and decided that wasn’t going to do for the whole track This is just two pieces of balsa spaced apart by two more (the same wood but filed a bit thinner) so that the links are held between them rather than falling to the side. I can put runs of ten together like this, insert the wire and snip it off.
