PzKpwf II Luchs 1:25 Wak
    [Finished] PzKpwf II Luchs 1:25 Wak
    Hello!!
    Time to start a new model
    This time I will try to build the PzKpfw II Luchs from Wak.
    [/URL]
    The main frame was to be built of lasercuts....
    First the drawing
    Parts for the frame
    When I had assembled the frame I noticed something was wrong......I had done the most stupid error you can do.I had assumed both sides of the frame was equal.They were NOT!!!! So with a massive punch from my fist the laserparts hit the dust.....
    I then had to make the frame the old fashioned way.....yes thats right,by cutting new parts
    So here is what I have done so far.....
    Next will be to add some smaller pieces on the frame and make the air vents at the rear end.
    can you get modern tanks in card? i know you like your german stuff but it would be great to see you make something like a challenger II or a type 74 or something like that. keep up the good work!
      Hello Richard!
      I also have modern tanks as the Russian T55 and T54, The ChallengerII and I'm going to get the leopard.I guess all kind of armor are covered in papermodels.
      The reason I build the German tanks is just that it was on top of my pile
        Hello Johnny
        Doe's it mean you will have to paint the new parts or will they be hidden only asking to see how you will get the paint and printed details to match up
          Hello Tony!
          The frame will not be painted.It will be covered by the outside skin that is already painted.So to make the outer skin to fit....it's all a matter of clean cuts
            Air vents
            The air vents.
            The air vents are placed on the rear side of the tank and is built up by several parts.
            The drawing shows what to do.
            Here I have cutted out the parts for the #13
            The assembly is straight forward.All parts fit fine.
            I bought some mesh from RaiRo since I have not been quite happy with the Gaz bandage I have used earlier.
            And with the mesh installed the top frame is lookig quite nice
            And the air vents installed into their proper holes.
            Note! nothing of the air vents is glued yet. I will wait to glue the vents in after the top skin is in place....just to be sure everything fits!!
              Getting dressed
              Putting on the skin was pretty much straight forward gluing.Some minor glitches was discovered in the kit,so a little trimming here and there was to be done.
              First the hull.
              Then the upper skin.
              Since the side "windows" will be in open position,I had to make the inner part.
              The turret
              All skins in place.
                The rear air vent
                The rear airvent.
                The internal frames
                The mesh and top frame
                All 3 vents in place
                  The turret
                  I have now started on the turret.
                  Made the two main hatches.
                  More tomorrow
                    Continued working on the turret.
                    Made the rear hatch with hinges,the antenna.the small hatc on top,the tower "window",two hooks at the back of the turret and some piece on front of the turret.
                      The Turret is done!!
                      Finished the turret today
                        Once again an amazing amount of detail and a superb build thread. Thanks for taking the time and patience to do this for us.
                        What is the gun made from?
                          The gun is a brass barrel Painted with H-Gunmetal
                            The front base for the drivewheels......I'm not sure what that part is called
                              Hello!
                              I have started to make the wheel cionnectors and the suspension.
                              First I noticed there was something wrong with the parts 64....I could not make the part fit the way it was.So I had to do some investigation,and luckily I found some shots of the real luchs that showed the part.I found out that the part missed some scorelines and the instructions are really BAD on this point and doesn't show the part in it's final shape at all.
                              Here I have placed the scorelines there they are supposed to be.
                              The scoreline should be as wide from the scoreline that shows as the part 64B is.When that problem was solved it was no problem to continue.
                              That was one damper.....3 to go
                              I also made a small hatch on the rear.
                              Now I'm off work for 3 weeks......so I will continue the Luchs when I return
