IDF D9R
  • minitnkr
    Charter Rabble member
    • 7552
    • Dayton, OH USA
    #16
    A real PE exercise. Beautiful work.
      • 15746
      Hi Mike
      As Paul says the pe work is exceptional.
      • Mini Me
        • Jun 2018
        • 10711
        #18
        Nice!
        • JR
          • May 2015
          • 18273
          #19
          !:thumb2::surprised::flushed::upside:!
          • Isitme
            • Nov 2020
            • 795
            #20
            Update,
            Again many thanks to all that have 'Liked' and also commented on the build.
            Well I hope you all had a good Xmas, our's was so quiet even the grave stones left for brighter lights (just joking).
            So a couple of days before my neighbours break-in SWMBO decided that the washing machine needed a long required update (I thought she was washing the housebricks, honest). After inspection and some research it was decided to change the 'shock absorbers'. Twenty minute job.... Sent away for the new ones that arrived the following day and were the correct ones. So dogs cleared of to safer climes, toolbox duly brought into the kitchen, machine pulled out from under the worktop and first job was to turn off the cold water supply to the machine. Turned the little blue tap to the required position, out with the stilsons and started to undo the pipe inlet at the machine... Question - Why when you know something does not seem to be correct do you continue anyway ??? As with all water connections you get a little water left over in the pipe and have a bowl ready to catch the surplus.... Thinking to oneself while truning the connection "That water looks a bit fierce squirting out, but it should settle once to pipe is disconnected... NO!!!! It was like trying to wrestle a mad snake, I was soaked, SWMBO was soaked, the flood was starting.... Crimped the pipe by folding it in half to stop the flow and duly handed it over to the backup (SWMBO) to hold - water still continued to force its way through, bowl full, bucket full - empty both... Into the cupboard under the sink to inspect the blue tap - tap was turned so that it would not matter which way you turned it it would not turn off the water, in other words knackered. And while wotking on that I kept seeing this red dye everywhere, question to SWMBO "Wheres all this red dye coming from" (expletives removed) Answer it is not red dye it is blood. Checked myself and sure enough I had a cut about 25mm along the pad of my thumb and must have nicked a vein, the stuff was everywhere. So a roll of kitchen paper later and two hours of mopping up I did eventually change the shock absorbers - but the problem was the front door seal had given up the ghost.
            Later that night SWMBO twisted the knife in my injued pride by announcing she had just bought a new washing machine and I need not have bothered :tired::confounded::worried:....
            So here is the build so far.... a mock up for the camera....
            And now with the cab and blade 'attached'...
            And with the non-slip which on the real vehicle seemed to be an afterthought.
            And that is it for this update - still putting brass on the cab - more later
            Mike.
            • scottie3158
              • 14221
              • Holbeach
              #21
              Mike,
              glad you had fun with the washing machine. The dozer is really taking shape.
              • JR
                • May 2015
                • 18273
                #22
                Younger than me but older then him.
                I nearly fell off the chair reading the attack of the hose, in fact it was a good job I wasn't partaking in liquid refreshment.
                The dozer is superb, love the dirt left on the blade, typical of your attention to detail.
                • Allen Dewire
                  • 4741
                  • Allen
                  • Bamberg
                  #23
                  Damn Olderthanme,
                  If it wasn't for bad luck, you wouldn't have any at all. Chock it up to Murphy's Law and I hope the thumb is healing up well. How's the new washer working???
                  BTW, one helluva nice dozer your building there Mike with the your usual finery!!!!!!!!!!!!
                  Youngerthanyou
                  • minitnkr
                    • 7552
                    • Dayton, OH USA
                    #24
                    Thanks Mike, my wife & I had a great laugh over your story. brought many fond memories. BTW, great dozer work.
                      • 15746
                      Hi Mike
                      I know I shouldn't have but I did laugh at your washing machine repair saga. Good job your modelling is better than your washer repair skills. The bulldozer is looking superb.
                      • Isitme
                        • Nov 2020
                        • 795
                        #26
                        Hello John
                        will email you Wednesday.
                        Mike
                        • Isitme
                          • Nov 2020
                          • 795
                          #27
                          Update,
                          Hello John, Scottie, Allen, Paul and Jim,
                          Pleased I brought a bit of humour into your lives - the problem is that you know there is something not quite right, but you still have to carry on... I had the water escaping under preasure and still the brain was telling me to keep unscrewing the attachment. Luckily there was very little damage from the water, and it was pure Laurel & Hardy at work, and yes we still laugh and any injuries are healing and the new machine arrives Wednesday.
                          Mike.
                          • adt70hk
                            • Sep 2019
                            • 10429
                            #28
                            Mike
                            Firstly great work on the kit. Secondly, sorry to hear about the washing machine woes..
                            ATB.
                            • Isitme
                              • Nov 2020
                              • 795
                              #29
                              Originally posted by adt70hk
                              Mike
                              ATB.
                              No, not woes, just life in an ordinary disfunctional household where I am the only sane one in it, and I have the paper to prove it :tongue-out3:.
                              • Neil Merryweather
                                • Dec 2018
                                • 5199
                                • London
                                #30
                                superb stuff there, Mike. I am in awe as always!
