It is very much personal preference Mike. There are modellers out there who will paint all the running gear and tracks on the vehicle! This I have never understood because as you say you want to reach all areas of the build. When you go down in scale ie 1/72 then its more common. However at 1/35 scale I find it easier to paint and weather the tyres, wheels, tracks and lower hull on a separate basis. As your skills increase you will want to get into the world of weathering and pigment work. This will give you the opportunity to bring all the separate units together as final weathering can be done once all the wheels, bogies and tracks are attached to the lower hull.
For your first build its turned out really well and all heading in the right direction. Keep up the great work my friend
