Marder, Tamiya, 1/35
  • PaulTRose
    • Jun 2013
    • 6455
    • Tattooine
    due to having to deal with the real world for quite some time ive not touched a kit since the start of november but i need to get back to it now things are settling down
    model making has always been what i do to relax or destress and at the minute im very aware of my own mental health so ive made the effort to tidy up the bench so i can make a start on something
    taken me a while to decide what.........its been so long i feel like im starting again!.......so nothing complicated, .........no plane with lots of masking,,,,,,,no car needing a shiny paint job,,,,,,,so a plain jane green afv is called for........and an old school tamiya to keep it simple
    found this in the stash........part of what was once a project to do a lot of West German/Unified Germany vehicles.......never started the project even though theres a load of kits in the overhead stash storage facility (loft)
    now theres 2 things i always do with 1/35 vehicles if i can
    first is to use a bit of threaded rod and a couple of nuts......drill a suitable hole in the bottom and bond in a nut. with No Nails type stuff.......screw in the rod and it becomes a removable handle.....block of wood with a hole becomes a base
    second thing i like to do is add some mass in the hull.........cos it makes the vehicle sit on the tracks better, also dosnt feel so 'toy like' when you handle it
    somewhere i have a box full of all sorts of scrap bits of metal......giant nuts, blocks of steel, stuff like that, but i cant find it anywhere!....and just couldnt think of something else i could use that was cheap (free!)
    so i thought a bit laterally............ive used a couple of new foil trays like a takeway ones......cut them up and made a couple of 'boxes' that fits just right in the hull. Bonded in with No Naily stuff
    i mixed up some gloop.......50%/50% of wall filler and sand......had a bag of sand in the shed and thought it would be heavier than just the filler, filler acts as the binder to hold it together
    going to leave it a day or so to harden off but i think its going to work
    Per Ardua
  • Airborne01
    • Mar 2021
    • 3962
    • Steve
    • Essex
    That's a novel approach! I sometimes do the equivalent but use a chunk of lead roof flashing (left over from younger,more adventurous days) held down with 'gator glue, If the roll of lead expires (prob not in my lifetime!) I'll certainly use that thanks!
      • 15669
      Hi Paul
      I'm glad you have the time and inclination to return to the bench. A Tamiya kit should at least have no fit issues. I have also used the 'handle' idea but not thought of adding weight. That's definitely an idea to try.
      • adt70hk
        • Sep 2019
        • 10402
        Nice start Paul!!
          • 18892
          Good tips there Paul, and good to see you back at the bench. I think I’ve seen you describe the nut and bolt idea before? I wish I’d remembered it when I started my KV-7 because spraying on a handle is far better than hand holding :thumb2:
            • 15669
            The vicar wants his lead back as the carpet by the altar is getting ruined ! :rolling: :smiling:
            • stillp
              • 8090
              • Pete
              • Rugby
              Good to see you back Paul.
              • Airborne01
                • Mar 2021
                • 3962
                • Steve
                • Essex
                Wasn't me Guv - honest! :rolling:
                • Andy the Sheep
                  • Apr 2019
                  • 1864
                  • Andrea
                  • North Eastern Italy
                  Paul, I like the idea of adding weight to tank models and your way is definitely an original one. Moreover, that would allow me to recycle the foil trays we use for our neighbour's cat, a guest we host for breakfast nearly every morning :smiling: ...
                  ...and my liking it at first sight fosters the suspect I should have family roots in Genoa and some tartan or Wensleydale in my blood... :money-face:
                  Andrea
                  • PaulTRose
                    • Jun 2013
                    • 6455
                    • Tattooine
                    got the hull upper on this afternoon......took a bit of persuasion as it has a slight warp
                    Per Ardua
                    • scottie3158
                      • 14201
                      • Holbeach
                      Paul,
                      Good to see you back fella.
                      • PaulTRose
                        • Jun 2013
                        • 6455
                        • Tattooine
                        ready for some paint tomorrow......hope the air brush works.....not used it since october!
                        Per Ardua
                        • AlanG
                          • 6296
                          Bit late to this one Paul but, from a personal perspective it is fantastic to see you back posting again given your reasons.
                          Coming along nicely and hopefully gives you a little bit of peace when you are building
                          • PaulTRose
                            • Jun 2013
                            • 6455
                            • Tattooine
                            kit was so old i had problems with some of the decals, the crosses and numbers self destructed when they came out the water, and i only managed to save the others.........so i had to get creative.......those crosses came from a sheet of decals for an Airfix Lynx in 1/72!......close enough in size to do
                            next step is get the tracks painted.....weather the hull and all the wheels (ive got a tub of MiG 'wash for green vehicles'....never tried it, so this might be its time)............then put it together and see what we got
                            Per Ardua
                            • JR
                              • May 2015
                              • 18273
                              Looks a good start Paul , and nice to see you posting again .:thumb2::thumb2::thumb2:
