Scotties panzer lll
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    #61
    Not a problem Paul, fire away!
    • Mickc1440
      • 4775
      #62
      Hi Scottie, as usual I must have been asleep somewhere and completely missed this but better late than never. Only seat left up in the gods. Really nice looking kit for you to work your magic on.
      • scottie3158
        • 14201
        • Holbeach
        #63
        Mick,
        No worries mate, there are so many great builds going on it is hard to keep up.
        • scottie3158
          • 14201
          • Holbeach
          #64
          The build is going on slowly but surely. I have removed the fenders and replaced them with the etch offerings the kit took some fettling as the etch is designed for the Italeri offering. I think they look ok I might give them a few dints later.
          I have decided to go for the up armoured version which has some additional armour to the front of the drivers position and the mantlet.
          I have just noticed a tab I have failed to clean up.
          cheers
          Scottie
          • Steve Jones
            • 6615
            #65
            Nice update my friend. Not seen screw heads moulded into etch before??? Did you have to do something to create the look??
              • 15687
              Hi Scottie
              The pe looks good. You made it fit fine. Definitely nice sharp details.
              • scottie3158
                • 14201
                • Holbeach
                #67
                Hi Steve, No the detail was in the etch and looks pretty good. This is the Aber set. I do need to tidy up the hinge a bit tho looking at the picture.
                Originally posted by Jim R
                Hi Scottie
                Jim, yes it is quite nice and saves me making it lol.
                • scottie3158
                  • 14201
                  • Holbeach
                  #68
                  The rear hull has been fitted. Replaced the kit tow rope with some copper wire. The vehicle has two ropes but decided to fit one the other is MIA.
                  Next job is to start detailing the track guards and adding the pioneer tools.
                  cheers
                  Scottie
                  • Mini Me
                    • Jun 2018
                    • 10711
                    #69
                    Up to your usual "high" standards there Mr. Scottie. :thumb2: Rick H.
                    • Jack L
                      • Jul 2018
                      • 1270
                      • Cheltenham
                      #70
                      Those hinges…:flushed: Love the screw detail as well
                        • 15687
                        Hi Scottie
                        Very neat building. Worth the time as a clean, careful build makes painting easier.
                          • 18901
                          Building up well with your trademark finesse on the detailing Scottie. Great stuff…..
                          • adt70hk
                            • Sep 2019
                            • 10409
                            #73
                            Scottie,
                            Looking very good indeed.... That edge does look very good indeed.
                            ATB.
                            • scottie3158
                              • 14201
                              • Holbeach
                              #74
                              Thanks Rick
                              Jack, thanks mate the Aber etch is pretty good.
                              Hi Scottie
                              Cheers Jim thanks fella that's good I need all the help I can get when painting.
                              Thanks Tim, apart from the PE I haven't had to scratch anything apart from drilling the hull MG barrel.
                              Originally posted by adt70hk
                              Scottie,
                              ATB.
                              Cheers Andrew, not sure what edge you mean though.
                              • adt70hk
                                • Sep 2019
                                • 10409
                                #75
                                Damn autocorrect....etch....
