Excellent progress. The scratch & PE work is looking great. I love the fact the etch on some of the brackets also shows the screw heads. Following along
Los
Thanks Los, The Aber etch is good with some detail like the screwheads but the detail is soft in other areas.
Using the instructions from the interior RFM kit I have added a little interior detail. It is not accurate by any stretch of the imagination but just adds a little bit of detail should you look in. I may get some crew members that will pretty much block up the hatches anyway.
Progress is slow but I'm chipping away. Work on the turret includes kit parts, PE and scratched items. The vision blocks on the side can be opened and closed.
I replaced the cast hinges on the turret bin with scratched hinges.
The braces were made from strips of pewter and punched rivets were added to the lifting hooks.
The cupola was a pain but it is done now. It does need a clean up. The armoured vision block covers can be shown open or closed. I have some crew figures on order so I will probably hide all the detail anyway.
