Thanks guys
Thank you guys
With the exhaust completing the weathering stages to the lower areas and running gear it was time to move onto the cab and load bed. The wire cutters first required painting. These were brush painted with Vallejo acrylics and the cab tarp received some acrylic highlights. The first weathering step was to apply a diluted pin wash with MIG Neutral wash enamels mixed with white spirit. This was applied in small quantities around all the raised details. I wanted the effect to be pretty muted so after approx. 30mins the areas were cleaned up with white spirit leaving only a faint trace of the enamel wash. AK enamel rust was then carefully added with a fine brush over the larger scratches and scuffs. Abteilung 502 grease was then added to the bottom of an old 1/35 Tamiya oil drum (without the circular bottom portion) and spillage marks added to the load bed floor. These effects will be allowed to dry overnight and checked whether more clean-up is required before moving on
Tool painted, cab tarp highlights and pin wash added
Rust effects added
Oil stains added to load bed floor
Thank you guys
Rust effects added
