Dragon 1/35 M4 Mortar Carrier
    After finishing the Cobra for the helicopter GB, I cast around & picked up this:
Name:	M4 Mortar Carrier.jpg
    It's been a long time since I picked up a Dragon 1/35 model.
    The model has been in my stash for a long, long time, and although it hasn't been started. I did go through it & discard all the 'not for use' parts - I just hope that the instructions for this were correct! ( although Dragon are not noted for their instructions! ) The model dates back to 2007, has PE, turned aluminium, and what looks like a few resin parts. I'll put up some pictures etc tomorrow..............
  • langy71
    • 1950
    • Chris
    • Nottingham
    Looking forward to this Dave,
    I've always wanted to build a halftrack since seeing the old Matchbox Half-track years ago, but never got around to doing so..
    • Steve Jones
      • 6615
      Going to be doing this one at the end of the year so looking forward to seeing how you get on, especially how you tackle the track/wheel combination for painting
        The last US halftrack I made was the Tamiya M16 Quad 50 calibre carrier, a very basic model ( it dates back to 1975 ). That had vinyl tracks - the Dragon tracks are solid plastic, and look much better. The tracks, in reality are rubber mouldings with cable inserts, so painting will be a bit different to normal tank tracks. I'm going to have to lay the parts out & look at the instructions to see if I can assemble them off the model.
        I'll also have to put away the 4B0, and dig out the Olive Drab...............
        • Steve Jones
          • 6615
          What I have heard Dave is that there is a way of doing it where you put the back track half on first, then the wheels and then put the front track half on??? As I always paint my wheels off model I will be interested to see how you tackle it my friend. Good luck
          • JR
            • May 2015
            • 18273
            I shall follow, like the way you change types like this .
              I looked up the instructions on Scalemates, and I think the best way to do it is exactly like Dragon recommends there:
              [ATTACH]450474[/ATTACH]
              That is, build the suspension bogies, the drive sprockets and the idlers separately, then glue the bogies to the hull, followed by the inner track halves with the sprockets and idlers, and then the outer track halves. You can paint all of these off the model, and would then only need to touch up the join between the two halves of the track.
                I'd get bored doing the same every build. Flexibility!! - In the MN, one day I could be in the clean workshop, overhauling diesel injectors, the next unblocking a sewage pump!
                  Sprue shots - big gaps, as the 'not used' parts have been discarded
ID:	1173395Click image for larger version
ID:	1173396Click image for larger version
                  X 2
ID:	1173394Click image for larger version
ID:	1173398Click image for larger version
ID:	1173399Click image for larger version
                  Normal Dragon style, ziploc bags with PE, clear bits, decals & what seems to be resin sprocket wheels.
                  You can see the unused parts - no idea what happened to them!
                  Normal Dragon instructions - they look OK, but Dragon have a poor reputation for accuracy in numbers!
                  A few detail shots to follow.
ID:	1173404Click image for larger version
ID:	1173406Click image for larger version
ID:	1173403Click image for larger version
ID:	1173405Click image for larger version
ID:	1173407Click image for larger version
ID:	1173409Click image for larger version
                    The parts are very crisp, no sign of flash, or sinks. Quite a few ejector towers to remove. The parts date back to 2007, and are still very good, even by modern standards. I reckon the one-piece chassis wouldn't be done now, in favour of a flat back assembly - anything to get that parts count up!
                      • 18907
                      Interesting subject Dave. I donโ€™t think Iโ€™ve seen a US half track built for ages.
                        • 15704
                        Hi Dave
                        As John noted you certainly go from one genre to the next with ease. The kit looks rather nice.
                        • adt70hk
                          • Sep 2019
                          • 10409
                          Looking good Dave. Those parts do look good but I hope you've not got any missing. As Tim says not seen a US half-track done for ages.
                            Slightly overran my time ration, but bits were fitting so well I got carried away!
                            What I thought were resin sprockets are very finely moulded polystyrene - really delicate & complex little single piece mouldings............................
                            After a bit of puzzling over the instructions, parts started fitting together - a bit of cleaning up here & there, but nothing of any consequence. One of the decisions I will have to make is when to start priming - not a problem as yet as most parts are OD.
                              I found the first glitch in the instructions -
                              This is a hangover from a previous model - it is the PTO for the front winch fitted to later half-tracks - this model has the earlier obstacle assist roller, so not applicable.
                              Assembly continues on the chassis........................
ID:	1173513Click image for larger version
ID:	1173514Fit is excellent - the only difficulty was with the exhaust pipe - it can only be inserted into the assembly one way ( remember the bent nails metal puzzle ? )
                              I stopped at this point, my hour or so was up - and the next section introduces some PE, so that can wait until tomorrow. The parts are fitting together so well - I have a bad feeling that I'm going to find something really nasty on the next page!
