Dragon 1/35 M4 Mortar Carrier
    • 18931
    Looking very good so far Dave. Good catch on the PTO. I wouldn’t have known that, so would have just added it and wondered what it did
      You could fit it, and it wouldn't be seen, unless you picked the model up..............
      • Graeme C.
        • 1611
        • Graeme
        • UK
        #18
        Interesting build Dave, I'll follow your progress.
          • 15737
          Hi Dave
          Glad you're still keeping an eye on your desk time - well mostly anyway :rolling:
          Chassis is looking good and only one instruction error so far.
            Main part of the chassis ready for priming: masked off the mounting points for the suspension bogies
            The suspension bogies are a fiddly little assembly - tweezers are essential - all the bits on the left go to make the assembly on the right.........................
ID:	1173580I'll finish the other bogie off & that'll be it for the day. Tomorrow, I'll crank the compressor up & give an overall spray of OD primer.
            • scottie3158
              • 14220
              • Holbeach
              #21
              Nice work I did the AFV meat chopper and the assembly is pretty much identical. You are making great progress.
                After a dose of primer, then a topcoat of Vallejo ModelAir Olive Drab, I painted all the rubber bits AK3 Tyre Black & the tracks AK3 Anthracite
                Then - the assembly! - Whichever way you assemble the tracks, they're going to be a bit of a tussle! You can see where bits go, but you have to flex those tracks alarmingly to get them to go over the roadwheels/return roller. Anyway, after a 30 minute wrestling match..........................
ID:	1173706Click image for larger version
ID:	1173707Click image for larger version
                OK, I've had to go round and touch up all those bits of paint that I scraped off during the extensive handling needed! I reckon that's the most difficult part of the model completed now. I'll have to paint the exhaust pipe, but that's the chassis ready to be put aside for later!
                • scottie3158
                  • 14220
                  • Holbeach
                  #23
                  Dave,
                  Looks good mate.
                    That came out well, good to know it’s a bit of an exercise to get the tracks on but you got there without anything breaking, so I’d say all is fine
                    • adt70hk
                      • Sep 2019
                      • 10426
                      #25
                      Coming on very nicely Dave, Looking good so far!
                      ATB.
                      • langy71
                        • 1950
                        • Chris
                        • Nottingham
                        #26
                        Love this Dave, a really clean looking build.
                          If I were to make this model again ( extremely unlikely, as they're very expensive ), I'd not add the road wheel bogies where the instructions say. I'd assemble each track unit, adding the sprocket & idlers loose & inserting the bogie loose into the track assembly. Then I'd offer the whole lot up to the chassis fitting over the drive shaft, idler axle & fitting the bogie mount onto the chassis rail. Keeping them loose should just give enough jiggle room to ease the parts together. Adding a few drops of TET should hold it all on place - considering the struggle to get it together. Sorry if this sounds weird, but I'm running through it in my head, the way to assemble it with minimum grief! ( not the way I did it! )
                            • 15737
                            Hi Dave
                            Well done with the tracks.all looking good.
                              • 18931
                              However you did it Dave, that’s looking very smart :thumb2:
                              • JR
                                • May 2015
                                • 18273
                                #30
                                Agree with the guys it's looking good . Good for you getting those tracks on.
                                Personally I like that premade chassis, that's what's puts me off from trucks and builds like this .
