Dragon 1/35 M4 Mortar Carrier
So how come your gallon is smaller than our old gallon then Ron…..and your mile is actually defined in terms of SI units…..I bet your red coats aren’t even the same shade as ours. Personally I blame Napoleon….Comment
Now, Now!! - I have a distinct bias against the US and their shunning of the metric system - I had to duplicate several mechanical bits & pieces I had designed, so our US subsidiary could use Imperial bearings. They could cheaply source them locally - the metric bearings I had specified weren't widely available in the US, & were expensive. So we had two sets of parts, visually identical, but not interchangeable, one for the US & the other for the rest of the world! Not the end of the world, but annoying!
The US subsidiary had to have a certain % of locally sourced parts in their products - some tax reason, I believe. I had to redesign an ignition system for a diesel to gas conversion set, the parts that were available in Europe, weren't in the US & I had to make do with some really klunky parts that were designed for much larger engines ( but available in the US )................
DaveComment
Just my thoughts , metric is so easy to work in as opposed to Imperial.
Looking through old wood working drawings ( sad I know but nice to look back at ) the thought of having to mark sections out prior to machining in Imperial it's no wonder that I converted to the metric system .
As to Dave's build its made me want to get up and carry on with some yes you read right tracks .Comment
go for it - they won't go away, they'll still be there tomorrow, and the day after, unless you do something about it! :smiling4:
DaveComment
If your kids are were catching on quickly Jim then I must not have been in your class because I was the one in the back row looking out the window at butterflies lolComment
I spent all my schooldays & college days using the metric system - My first ship was built in 1959 & she didn't have anything metric on her - I had to deal with PSI & degrees F, gallons, tons ( as opposed to tonnes ) inches watergauge, all the bolt threads were BSW or BSF - the lathes were imperial, as were the micrometers, verniers etc etc. It could be confusing at times!
Some measuring gear did cross over to metric as well - like degrees twaddle hydrometers. Things which now would appear as curiosities on the Antiques Roadshow!
DaveComment
Without wishing to completely derail Dave's thread, just my two penneth......
I was born in 1970 and so was only ever 'officially' taught the metric system and yet me default in every day life usually imperial....stone/lbs, mph and feet and inches. it's probably in part down to my dads' influence. He was obviously brought up on imperial and because so much was still done that way, thought I needed to understand the old system as well as the new one - he was equally at home in metric though. And yet when it actually comes to doing any actual work e.g. DIY at home, I do all measurements in metric because it is obviously so much easier to work.....
ATB
AndrewComment
More derailment……I was taught metric from about the age of seven, so never really knew anything else…..until I started work. The dyehouse I started my first job in was completely non metric. I had to have a crash course in non metric measurements, including temperatures. The real eye openers were apothecary measurements for weight……I knew pounds and ounces, but had never heard of drams, scruples and grains before I worked there…..Comment
In our defense, I think the last entirely Imperial measure automobile was built in 1974. We are a somewhat larger ship to turn. The UK has one seventh the economy, about a third the population, and fits comfortably within 11 of our 50 US states. Jus say'in. Plus you have a gov'mint and population that works together a site' better.Comment
