US Army M32B1 Tank Recovery Vehicle
    Here are the wheels and bogies:
    [ATTACH]454240[/ATTACH]
    The white bolt heads on four of the bogies is because on the real thing, a plate could be bolted to them to lock out the suspension when lifting heavy loads with the crane. These bolts are screwed into the normal holes that are in the fronts of Sherman bogies anyway, so I only had to drill out the middle bogies to show those. The lip at the top of the front and rear bogies, above the bolts, is a shear plate that the bolt-on plate sits against, so the weight of the tank and load isn’t borne by the bolts.
    Because of the heavy mine roller, I also adjusted the suspension so the nose of the tank will be down:
    [ATTACH]454241[/ATTACH]
    Tasca (and Asuka) provide plates to go inside the bogies to regulate the suspension height. I used A (1.5 mm) at the front, A+C (2 mm in total) in the middle and A+B (2.5 mm) at the rear. To do this, though, I had to cut and chisel out the track that the spring package sits in on the inside of the rear bogies, else it wouldn’t go down far enough. That, then, is why there is filler on the rear right bogie: I accidentally went through it with the chisel …
    (Shermanophiles may not that I used a bogie with “high” return roller mount at the front left, basically because I can The idea is that the sharp-eyed viewer may notice this is a replacement bogie.)
      The interior is now mostly finished:
      [ATTACH]454365[/ATTACH]
      On the framework on top of the floor, there will be a plate on the left and right, so it will obscure more of the stuff I built than is the case now, and the winch drum in the middle will do the same. Here’s what I put behind the driver’s seat:
      [ATTACH]454366[/ATTACH]
      This is the winch transmission (low, high and reverse gears), which is driven via a chain from the transmission shaft. As the chain has a cover over it, I represented that with the front piece of plastic card. I skipped building the rear of the winch transmission, as it won’t be visible anyway. Under the floor, I added the visible bits of the actual winch drive and another chain cover:
      [ATTACH]454367[/ATTACH]
      What it still needs is some levers, at least the winch gearshift and clutch, as well as the tank’s handbrake and possibly also the tank’s gearshift lever.
      • scottie3158
        • 14208
        • Holbeach
        #48
        Nice additions certainly gives the interior a busy look.
        • Lee Drennen
          • 7711
          #49
          Jakko nice updates and scratch work
          • Airborne01
            • Mar 2021
            • 3989
            • Steve
            • Essex
            #50
            Now I know why I 'tasked' you mate ... Looking good!
              That’s what I’m aiming for The hull front was just too empty, and too obviously so, to leave it alone
              Thanks Though it’s not that great, as it’s all actually a pretty quick bodge job — even if I walked away from that winch transmission a couple of times because I couldn’t get my head around a good way to build it. This afternoon, I took another look at the technical manual (most of the relevant pages:
              ) and just went for it with scraps I found on my workbench
              Now I know why I should stop building models with an interior …
                There is a Dutch saying that translates as “He who keeps something, has something.”
                [ATTACH]454525[/ATTACH]
                These are the bits for the winch. Tasca give you the bright yellow thread and the two green parts. I didn’t feel like trying to turn that yellow thread black, so I looked around for black thread instead, but found that if you order it online, you pay a lot more postage than the actual thing costs … So, because I was in town today, I went to a couple of craft shops to see if they had anything, but no luck (including “Oh, zero point seven millimetres?” after she had pointed me to thread about 5 mm thick … :rolling.
                Tonight, I was looking for some bits I could use to detail the model, and suddenly remembered I have a bag of leftover thread from kits … and yes, it turned out to include about a metre and a half of black thread of about the right thickness … Maybe I should have looked at that a week earlier
                Now, Tasca tells you to wind 150 cm of the yellow thread onto the winch drum. I think this is wasteful unless you’re actually going to show (almost) that much actually in use, so I was looking for something to increase the winch drum’s diameter. I couldn’t find tube of the right diameter, but looking through my aircraft spares box, I found the grey bit. This fits neatly over the winch drum in both length and diameter, only needing the slot at the end reamed out, the flange cut off and about half a millimetre added to its length.
                Inside the hull, I detailed the oil tank:
                [ATTACH]454526[/ATTACH]
                That’s the long, narrow, square tank in the corner. I added a round lid to the top from a piece left over from some unknown kit that was about the right diameter, and only needed a hole in the middle filled with a punched bit of card. The pipework is plastic rod and a little copper wire, the other stuff on the firewall is card, rod, strip and some Dragon canteens.
                • CarolsHusband
                  • Feb 2021
                  • 474
                  #53
                  There's an English saying " Better to be looking at it, than looking for it".
                  Love how the build is going Jakko.
                  • Caustik Filth
                    • Jan 2022
                    • 364
                    • Rob
                    • Portsmouth
                    #54
                    Heel mooie Jakko,
                    Looks mighty fine for a 'bodge job' to me mate. A true mage of the scratchity for sure!
                    Cheers Rob.
                      • 15723
                      Hi Jakko
                      That interior is looking much more than adequate.
                      Maybe I should have looked at that a week earlier :smiling3:
                      I'm sure we have all done similar. I once tried to sort out all the hundreds of left over kit parts. I gave up and they are back, jumbled up, in a big plastic box.
                      The oil tank looks excellent.
                        It could be done a lot better, I assure you But as I mentioned before, the front bits are there more to give the impression that everything is there, rather than to be truly complete and accurate. The stuff at the rear of the hull and inside the turret is more important because it’s much more obvious.
                        I did persevere with that, to a fair degree. I have separate boxes for several subjects (M113s, Shermans, M26–M60-series MBTs, German vehicles, ammunition (all of these 1:35 only), propeller aircraft, jet aircraft, 1:76–1:72 vehicles and more) but all the rest goes into one large “miscellaneous” box. Yes, I have too much, really … And then, with a model like this, I’m happy I didn’t throw out an insignificant little part like that round thing I used as the oil tank lid
                        It actually needs a little more work The real thing has a lip around the top and tiny bolts on the round lid, which I intend to add, as they will (hopefully …) show up well after washing and drybrushing the interior.
                          I’ve not been working on any models of late, so progress is a little slow … Also not helped by trying to think of a good way to build the fire extinguisher bottles. This afternoon, I suddenly remembered that I should have some from a Tamiya M113 somewhere, which should be about the right size. After a lot of rummaging around, I didn’t find them, but then recalled that the old and pretty awful Tamiya M60 kits have some too …
                          [ATTACH]455299[/ATTACH]
                          And luckily, I did find that part I cut off the handles and then glued on some rod to make the connectors on the tops of the bottles, as well as using stretched sprue to make the activation lines that run to them from the handles in the engine deck. It still needs some pipes from the bottles, but I’m still thinking about how to best do that.
                            The interior work is finally almost complete … first, I made some pipework for the fire extinguishers:
                            [ATTACH]455545[/ATTACH]
                            The second bottle isn’t connected, because it turns out almost all of this will be hidden by the left rear seat, so I didn’t bother showing more. I also moved the water bottles over to the left a bit, as they were too far towards the vehicle’s centreline.
                            At the front, I added the winch control levers:
                            [ATTACH]455546[/ATTACH]
                            At the left is the winch gear lever (here in low forward gear, more or less), the other large handle is the winch clutch (here shown engaged) and the small handle next to the drive shaft is the clutch for the power take-off (also shown engaged).
                            With the floor plates and winch drum in place, this is what you can see of all of that through the open top:
                            [ATTACH]455547[/ATTACH]
                            And because the clutches are engaged and the winch is in gear, there needs to be someone in the driver’s seat:
                            [ATTACH]455548[/ATTACH]
                            This because with the power take-off clutch engaged, the tank’s transmission would be uncoupled from the drive shaft, so the winch could be controlled by means of the tank’s gas pedal.
                            The figure has legs from a MiniArt set of American tankers, an upper body from a different such set, the arms are Asuka and the head is a resin one from Royal Model,
                              • 15723
                              Hi Jakko
                              Good progress. Frankenstein figure looks fine. Considering the different makers of his parts the proportions are very good.
                              • scottie3158
                                • 14208
                                • Holbeach
                                #60
                                Nice details, figure looks good.
