Centurion AVLB (slow build)
Not to panic, it may even not get finished in time, still got the base to do, but cannot do that untill it is finished. But I know there is a holiday around that time so may not even make it. First holiday in years - what do you do, do I still need to take a bucket and spade, do they give free boat rides. is it share a hotel with new friends.....
Wibble...Comment
Update.
The first bridge half is now hours near to completion. :relieved:
I have added most of the track side guards, with two to go on this half of the bridge.
Below is a pic of the parts that go to make up one section..
So you have the section itself, below that bottom right are the uprights, above and to the right are the four spacers, then on their left are the rear parts of the clamp that fit across from the rear of the section and over the edge of the flat strip. To their left are the same, but these wrap around the outside edge, and finally there are the 0.8mm nuts that attach the clamps (in real life).
Here is the bridge now at its full height...
And at its full length, with a Chieftain to give it some scale...
And now for a lay down in a dark room.... Only another half to go...
Mike.Comment
I think I’ll wait for somebody to make this as a complete plastic kit
Although, for the Centurion bridgelayer I would most likely build, there already is. It “just” needs combining a Centurion hull with an M48 AVLB mechanism and bridge …Comment
Different bridge dimensions and build, and different launching mechanism.
But, like all things scratch built and London busses, you wait for one and along come three... M113, scratch built - Tamiya brought out theirs... M577A1 based on the M113, again scratchbuilt one, and Tamiya brought out theirs. Another modeller I knew came out with the M10, you can guess what happened. Although I must admit it has taked a few decades to finally get the M114 in plastic...
Mike.Comment
If I were to build a Centurion bridgelayer it would most likely be the Dutch Army version, that differs as you say.
I bought the Accurate Armour M114 (second hand) years ago but haven’t built it yet. Oh, and I have their FV 432 as well, and bought their Strv 103 a few months before Trumpeter released theirs. I did kind of wonder why they (AA themselves, at EuroMilitaire) charged me 10% less than the list price on it at the time …Comment
Update,
The work on the bridge has been a bit hit and miss at the moment with having to do other things, house type things etc...
But we are progressing and can see the light at the end of the tunnel - or is that the bottom of the JD bottle....
Anyway...
#3 section in the jig....
... and now getting ready for the side guides to be put on....
So more later when I should be on #4 section.
Mike.Comment
Update,
Anyway...
[ATTACH=CONFIG]n1199693[/ATTACH]
[ATTACH=CONFIG]n1199694[/ATTACH]
Mike.Comment
Those bridge sections are absolute monsters! And to have to build four of them... Top marks and hats off sir!Comment
Just caught u with this and gotta say..... WOW!!
That's one inspiring bit of bridge building,looks superbComment
