Centurion AVLB (slow build)
  • minitnkr
    Charter Rabble member
    • 7541
    • Dayton, OH USA
    #286
    Well done.
    • Scratchbuilder
      • Jul 2022
      • 2689
      #287
      Jakko, Andy and Paul, many thanks, your support/comments are most welcome.
      Mike.
      • Scratchbuilder
        • Jul 2022
        • 2689
        #288
        Phew, had to go on a long search to find this one again.
        As you may remember I had a disaster with the original base and decided to go at it again....
        Well this is where I am today having worked on it along with other subjects...
        This is what it will look like once laid out on the display table
        There is still the 'water' to add on each section and at the moment I have 'water' from DeLuxe and Vallejo in pill cups to see if I get the problem I had last time, although this time I have sealed around the edges unlike the last base duh!
        Close up of the 'river' and the reeds.
        The groundwork was the usual 'grass' but after watching YT video's I then re-worked the 'grass' with the airbrush starting with a black basecoat and then mixing up some Tamiya NATO Green and Yellow Green, then applying that lightly over the basecoat. Next I added more Yellow Green to the mix and went over again but randomly. Gave it an hour to dry and then again went over the base with just Yellow Green which added highlights to the grass. The bare earth was then given a light coat of Buff, followed when dry with a mix of Buff ang German Grey which gave me a grey earthy look. This will now be followed today with a dry earth watered down Earth acrylic from Vallejo in random areas of bare earth and once dry a dark wash to tone down the earth some more... Then hopefully the 'water' will have hardened and I can check to see which is suitable.
        More later
        Mike.
        • Mickc1440
          • 4779
          #289
          That looks very impressive, better luck with the water
          • Scratchbuilder
            • Jul 2022
            • 2689
            #290
            That is why they are in the pill cups first, instead of just pouring and hope for the best.
            • The Smythe Meister
              • Jan 2019
              • 6248
              #291
              That looks excellent,love the track depressions, about 50% of the times I do that,they come out a bit "squashed" looking :flushed:,
              Water is something I've yet to try,(more of a Cider man!!:tears-of-joy,so I'll be following your progress with that particularly closely :tongue-out:.
              Great stuff this:thumb2:.
              • Jack L
                • Jul 2018
                • 1271
                • Cheltenham
                #292
                [ATTACH=CONFIG]n1208778[/ATTACH]
                [ATTACH=CONFIG]n1208779[/ATTACH]
                [ATTACH=CONFIG]n1208780[/ATTACH]
                More later
                Mike.
                I've gone for the painted grass method on my last couple of bases, and it was a bit of a face-palm moment as to how much better it looks!
                  • 15705
                  That is looking great Mike.i hope you find a satisfactory water.
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #294
                    It's the Gin that gets me every time :tongue-out3:
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      #295
                      I know, I have all these bases with the artificial grass which when the sun gets on it you can see little red glowing bits - I claim it is the Fairies, and if the person looks closer they can see the magic mushroom houses - had a couple that bent down to get a closer look and then realised.....
                      • Andy T
                        • Apr 2021
                        • 3239
                        #296
                        That grass looks great. Can't beat having a reference so close by! :smiling5:
                          Good to see this is getting close to the finish line
                          • scottie3158
                            • 14202
                            • Holbeach
                            #298
                            Looking superb.
                            • Scratchbuilder
                              • Jul 2022
                              • 2689
                              #299
                              Update,
                              Water worked, just got to add some ripples and movement and then place the vehicle in position and then the job is done phew! pics a bit later.
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #300
                                Well we got there, the water turned out clear and the bridge attached to the vehicle without any problems. The end pics will be posted on the completed sectionlater today.
                                Many thanks for all the kind comments and for sticking with the build.
                                This has been the longest build from research to finish (3 years) I have done and plan not to repeat it.
                                Mike.
