Centurion AVLB (slow build)
    Ah, I understand now why there are two widths in the photos — I was wondering about that. Glad to read you didn’t have to make a complete treadway from bits of plastic strip, as I feared at first
    Though to be honest, I would have looked for someone who owns a laser cutter for this: draw the pattern on a computer (which would be largely copy-and-paste-work) and just have the device cut all those little holes in a bit of plastic card of the right thickness.
      • 15679
      Hi Mike
      Just had a proper look at your earlier photos on the big screen. Brilliant work. Very neat and I can imagine the time taken. Wonderful work on the treadway. The building of the master must have tested your patience although the actual casting is fairly straightforward. You look to have nice, bubble free castings.
      • JR
        • May 2015
        • 18273
        #33
        Originally posted by Jakko
        Ah, I understand now why there are two widths in the photos — I was wondering about that. Glad to read you didn’t have to make a complete treadway from bits of plastic strip, as I feared at first :smiling3:
        Unfortunately he doesn't have any friends with such things:smiling3: I had one of those sketch things thought:upside:
        • stillp
          • 8091
          • Pete
          • Rugby
          #34
          Do laser cutters work on plasticard?
            Laser cutter are increasingly used for cutting of polystyrene (PS). Laser cutting is fast, flexible and very precisely.
            • Scratchbuilder
              • Jul 2022
              • 2689
              #36
              There are also studs that were added to all junctions (not visible in the pics). And you cannot use a laser cutter on plastic, it will melt it, plus why do it that way when the enjoyment is working out the problem youself and realising you have achieved something.
              • Scratchbuilder
                • Jul 2022
                • 2689
                #37
                That is polystyrene and not plastic sheet.
                • Scratchbuilder
                  • Jul 2022
                  • 2689
                  #38
                  Originally posted by Jim R
                  Hi Mike
                  Jack Daniels helped a lot to ease the pain....:tongue-out3:
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #39
                    And you still tried to use your crayons on it.... :smiling5:
                    No, they work on polystrene which is like foam rather than card.
                      That makes it a whole different game, yes. By casting it in sections you avoid adding a lot of pieces that you would have to laboriously add when cutting the plate as a whole.
                      The site I linked to (mainly because it was the first one I found) sells laser cutters suitable for plastic sheet that avoid this problem. Here’s an example from that site:
                      OK, these are industrial machines, but with a bit of luck, there are hobbyist-scale ones to be found with similar capabilities.
                      I think you’re confusing polystyrene in general with expanded polystyrene foam. Nearly all model kits are made of hard polystyrene, as is the kind of (usually white) plastic sheet/card most commonly used for scratchbuilding.
                      I also get that feeling after drawing something intricate But that’s the beauty of modelling and scratchbuilding, IMHO: you can build it the way you think works best, and I can get much the same result via another technique. Does that make either better than the other?
                      • JR
                        • May 2015
                        • 18273
                        #41
                        I also get that feeling after drawing something intricate :smiling3: But that’s the beauty of modelling and scratchbuilding, IMHO: you can build it the way you think works best, and I can get much the same result via another technique. Does that make either better than the other?
                        My thoughts on the last part of your post. Many times we have made items for builds, then time passes and you see a ready made item you have struggled to make . Then you think what should I do buy it or still make it . I think two things, how much does it cost against making one, and have I the time. This applies to me mainly when making buildings and trees .
                        • Scratchbuilder
                          • Jul 2022
                          • 2689
                          #42
                          Update.
                          So debate over tea drained and back to work..... Thanks Jakko for the information.
                          The rear support for the bridge is next on the agenda. First was the uprights and then the crossmember that will support the bridge during transport as seen in the earlier pics. Attached to this are the support legs used during servicing of the vehicle if the bridge is loaded. Also added was the new lifting eye just ahead of the support upright on both sides.
ID:	1182694Click image for larger version
ID:	1182695Click image for larger version
ID:	1182696Click image for larger version
ID:	1182697Click image for larger version
                          • adt70hk
                            • Sep 2019
                            • 10406
                            #43
                            As always Mike, such great scratchery in such a small space.
                            • Scratchbuilder
                              • Jul 2022
                              • 2689
                              #44
                              Next on the order of build are the two clamps at the rear of the cross members. I started with the locking wheel handles - these were made from copper wire wound around a suitable rod and then the resulting 'spring' was cut to to give me four rings (two replacements) into these was added the cross and the centre disc. Once complete they were given a blend of thin putty to try to give the impression of a cast item. The Clamp blocks are made from plastic card and are shown almost complete. I should add that the 'cross' is centered in the ring and the studs on the outside were added after.
                              More later....
ID:	1182699Click image for larger version
ID:	1182700Click image for larger version
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #45
                                Cheers Andrew.
