Centurion AVLB (slow build)
Update,
Well the tube cutter arrived, so it was jump in with both feet, first blood to the tube cutter, tried to turn a small length to make it smaller and now have a couple of extra fingerprints, no blood spilt.... I do not control a saw very well and the thought of sawing and then sanding and then scrapping a length of tube because I sanded far too much off it or one side was the decision to get the tube cutter (K&S). It is a basic tool made from plastic and nylon and for model making it does the job. I first marked out where the cut was to go and used the tube cutter to do the rest of the job, but first I did follow the pencil mark with a saw just to give the cutter blade a start and to line up the cutting blade.
So this is what I wanted to build...
This is an Australian version and you can clearly see the Rollers and their design of spokes...
So the first job in the construction was to build a jig....
Here is the jig with one of the centre hubs in place....
Next came the roller outer casing...
This was followed by the spokes a touch of c/a was added to the top edges and then the spoke was lined up at the bottom agains the small square of plastic and then the top moved into position to let the c/a set.
And there it is in its final build, all that was then required was to let this set up for about half an hour and then remove it and using an old scalpel blade (10A) I dipped it into some c/a and ran this down the joints at the inner bottom of the spokes - job done and onto another job - the lifting arm.Comment
Update,
Sorry for the lack of progress, see my failed Mustang or better yet do not look. But back on this asap.
Mike.Comment
Sorry I lost track of this build, Michael. The catch up was amazing :thumb2:
and some comments really made me laugh.:tears-of-joy:
AndreaComment
