Good idea — I had had the same thought and would probably have used it, except that I did some checking yesterday and found that the Hobby Boss Leopard wheels will sit about 0.5 mm too far out. This may not seem like much, but it noticeably puts the track at an angle, so I will need to modify the insides of the wheels to move them in by that amount.
These wheels are Tamiya-style, with a poly cap trapped between the two halves, and it turns out that the section of the wheel that actually holds the poly cap in, is about 0.5 mm thick … Of course, that means that moving the wheel closer to the hull results in the poly cap not being trapped anymore
I’ve been looking for material of about the right thickness that can be turned and drilled on a lathe to make inserts for the wheels so they will fit on the axles, but I haven’t found any suitable scrap yet.
Thanks, will do
Thanks
Though I must add that the research here is more, “what’s on other vehicles of the era” than looking into the actual VT 1-2.
Thanks, will do
Thanks
