Half the markings are now on:
[ATTACH]479695[/ATTACH][ATTACH]479694[/ATTACH]
The registration plate is from an Italeri M108, but cut up so I could turn 59597 into 97559. I’m not quite sure how Belgian vehicle registration numbers work, but I think the first two digits are the vehicle type — all Leopard 1s had 54, for example, and CVR(T)s had 65. I hope 97 had not been used yet in the mid-80s, but I don’t actually know
The 16 Armoured Division badge are also from the M108, modified as described earlier, while the bridge classification 44 comes from an Italeri Leopard 1A2. Takom gives you a 48 for this, but after looking up the VT 1-2’s weight (not quite sure what that was, but in the low-40s tonnes), I figured a little lower would be more realistic.
After taking these photos, I put a coat of matt varnish over all of them, because some didn’t seem to want to stick very well despite using Micro Set and Sol on them. The cut lines visible on the registration plates will be hidden later with some dirt and stuff
