Tamiya 1/35 Matilda Mk.III/IV
    Originally posted by Jakko
    I’ve gone rather off Hataka — I’ve tried a few of their airbrush-ready acrylics, with results varying between “sprays OK but not overly great” and “wouldn’t use again” so I’ve decided on the latter for the whole range to avoid frustration.
    Though I must say SCC 2 doesn’t really sound like the right colour for a Matilda … or are you using it as a base for something else later?
    Home Service tanks ( UK Mainland ) were painted with SCC 1A Dark brown over SCC 2 until 1943 - it's not a scheme you see very often - which is why I'm doing it.....................
    The Hataka paints just aren't consistent enough - I'll be using mine up, but won't buy any more
    • adt70hk
      • Sep 2019
      • 10400
      #32
      Nice start Dave!
        That’s what I meant: I didn’t know the Matilda II was still in UK service when that scheme was current.
        This is reason enough for me
          This is reason enough for me :smiling3:
          Last Matilda delivered August 1943...........
          • adt70hk
            • Sep 2019
            • 10400
            #35
            I heard that only the other day on a Tank Museum Q&A video and had no idea it was that late either.
            • The Smythe Meister
              • Jan 2019
              • 6248
              #36
              I expect that particular one was built in Devon then......
              ..... they probably STARTED building it in '39 !!
                It amazed me that there were around 70 Matilda II's in existence ( in various states ) - over 30 in Australia, since only around 3000 were made, a good survival rate
                Tracks assembled on one side - nice fit - just careful removal of the bits from the sprue needed
                Not concerned about the upper run - it won't be seen!
                Benchtime stopped for an odd reason - I've got hiccups! - you try applying precision drops of glue , with that! Can't remember the last time I had them!
                  Hiccups over - both sides of tracks finished, ready to move onto the upper hull
ID:	1191002Click image for larger version
                  The tracks are easy to assemble - the Tamiya fit is excellent, no impossible gaps left............
                  • stillp
                    • 8087
                    • Pete
                    • Rugby
                    #39
                    Waltzing?
                    (coat please!)
                    • Graeme C.
                      • 1597
                      • Graeme
                      • UK
                      #40
                      Originally posted by stillp
                      Waltzing?
                      (coat please!)
                      There's always one!
                      Lower hull & tracks are looking good Dave.
                        Originally posted by Graeme C.
                        There's always one!
                        It helps when the parts fit as well as the Tamiya ones do!
                        No pictures today, just primed the upper hull...........................
                        • JR
                          • May 2015
                          • 18273
                          #42
                          Thanks one paint I shan't bother with then Dave, nice work on those tracks.
                            Basecoat sprayed on the upper hull & side skirts
                            Tamiya would have you add all the tools before painting - nope!..................Turret - started assembly.
                            There is a crew supplied, but they are more suited to the desert options, so the hatches will be shut.
                              • Jan 2019
                              • 6248
                              #44
                              [ATTACH=CONFIG]n1191124[/ATTACH]
                              Looking good Dave
                              Don't understand why they say that with the tools..... noticed that on pretty much every Tamiya AFV I've built!
                                • 15653
                                I missed the start Dave. Looks a nice kit with typical Tamiya's good fit. You're making good progress. Tracks look very good. Hope the hand problem is improved. All the talk of captive nuts, waltzing and hiccups shows just how much some blogs include!! :thinking: :smiling:
