Tamiya 1/35 Renault UE Carrier
  • stillp
    • 8094
    • Pete
    • Rugby
    #16
    I'll be interested to see how you get on with that Mr Hobby cement Dave, I've got a bottle here.
      One thing you'll notice is the smell - not unpleasant, but a bit stronger that TET - another thing - the brush in the cap is too big, it needs trimming down to about half it's thickness, otherwise yo get far too much glue running around
      • stillp
        • 8094
        • Pete
        • Rugby
        #18
        Noted, thanks Dave.
        • Graeme C.
          • 1604
          • Graeme
          • UK
          #19
          You're making a nice job of this odd little vehicle Dave, just had a catch up.
          • JR
            • May 2015
            • 18273
            #20
            I'm in, bit late . Those tracks :anguished:. You managed them well :thumb2:
              Theyโ€™re fairly doable, nowhere near as bad as they could have been. Tamiya have sensibly kept the number of pieces to a minimum โ€” if you look at the picture of the painted tracks on the sprue that Dave posted, the smallest parts are two single links for each side, but most of the short runs are double and triples, which makes assembly a lot simpler.
              • JR
                • May 2015
                • 18273
                #22
                Says you
                  I've neglected this, working on the 3D printer, so I've progressed a little further
ID:	1193023Click image for larger version
                  The trailer needs its' tracks adding & the crew need to be sealed in, but that's the bulk of construction done. There's a few boxes, drums to add as loads in the trailer & the stowage box. Then a matter of weathering to add interest to what is rather a boring model............
                  • adt70hk
                    • Sep 2019
                    • 10409
                    #24
                    Sorry Dave completely missed this.
                    That's coming on nicely. The bottle gives a good idea of how small it was.
                    Keep up the good work.
                      Build Mengโ€™s Char 2C next and pose the two next to each other, that will get people talking about the UE. Once they spot it, anyway.
                        After a period of neglect, I thought I'd better pick this up again, or the bits will gradually disappear.
                        The carrier itself is just about finished, bar the tools & bin stowage & the trailer is awaiting it's running gear. It's on the base I printed out - scaled specifically to fit the model
                        The base was labelled 'cobble street', but I think it's more like stone paved
                        Either way, I think this type of road surface would have been common in France in the 40's
                        • Allen Dewire
                          • 4741
                          • Allen
                          • Bamberg
                          #27
                          Nice work Dave!!! The two together will make a nice little dio too. Shame it takes so long to print the base though...
                          Allen
                          • Neil Merryweather
                            • Dec 2018
                            • 5189
                            • London
                            #28
                            Allen
                            It's still quicker than making it Allen
                              Now I'm getting a bit of confidence in the printer - the top mounted filament spool & filament guide really improve the reliability, I can leave it to itself, so the time factor becomes less important.
                              • adt70hk
                                • Sep 2019
                                • 10409
                                #30
                                Good to hear Dave. Really looks like you're getting the hang of it!
