Looking splendid Andy. Very nicely done. Hope the bug goes quickly…..
The Smythe Meister's 1/35 Achilles
Must admit that I like the look of these things
Cheers Bob, it's a very enjoyable kit to build up
...and thank you too AndrewComment
The bug has been rather grosse,in fact quite worrying at times, however,after hearing of your,and other's,woes recently, I'll mention it no more!
ALL.... An update,of sorts,up and coming soon.Comment
So then, getting near to the finish line now, just need to get the camo netting sorted.As usual,I shall be using the very detailed and professional method/equipment...
.. oh,ok then,some cheap herbs, netting and PVA glue....
... done a bit so far,but another day at least of fiddlin' I reckon!! ....
.... also started the arse end with tools and camo net roll...
... Well then, I'm SURE I can get this done by the end of play tomorrow.
Thanks for looking in,
AndyComment
Sounds like the one I had a fortnight ago……it does go….eventually. Hell of a way to lose weight though…..Comment
As for the camo, it's only the bits I showed earlier,and no hill of beans to do....
For main Gun Barrels,I just cut some irregular strips of the netting,brush on a liberal amount of white glue,and press them into it,(just to fill it out a bit),then drape over larger pieces which hang down past the barrel... these should be longer,and fuller than you need,as you'll be cutting them back to where you want them later..
The camo roll at the back just involves a wooden skewer,saves wasting rolling loads of netting to get the bulk of it,then,white glue and wrap netting around it half a dozen times or so
Once it's set, more white glue,and then sprinkle LOADS of the herbs all over... PLENTY more than you need.When dry,invert model,shake off excess and voilà!!
Next!!...
Cut off, roughly,the excessive length with scissors/nippers,doesn't matter that it's a straight line,white glue remains flexible for days,so just tease the threads of the netting out, with tweezers, cocktail stick,and you can get a more uneven "drape".
If it all looks too similar,colourwise, just dab on various watered down Greens to suit.
Blimey,that makes it sound long winded eh?!!!...Comment
Thanks very much John :smiling3:
The camo roll at the back just involves a wooden skewer,saves wasting rolling loads of netting to get the bulk of it,then,white glue and wrap netting around it half a dozen times or so :smiling3:
Once it's set, more white glue,and then sprinkle LOADS of the herbs all over... PLENTY more than you need.When dry,invert model,shake off excess and voilà!! :smiling3:
Next!!...
[ATTACH=CONFIG]n1194637[/ATTACH]
