I’ve not used the Vallejo washes, but it sounds like you’ve got the exact same idea I do: better to have to add more later than it being too much straight away. Strong Tone has about the same colour as Tamiya Smoke, but dries matt.
I tried Mig washes, but don’t like them: they’re far too strong and on top of that, you have to keep shaking them every couple of minutes else all the pigment sinks down again. The Army Painter stuff is transparent paint, and I get along with that much better by making a wash of it myself. I should buy a bottle of Vallejo and see if it works for me.
It works well to draw the colours more together, though I think I will need to go back and drybrush with the Light Olive again because the highlights have mostly disappeared now too. This was a bit of an experiment to see if it would be better to highlight before the wash, instead of after as I normally do, and maybe it will work if I make the highlights a little stronger?
One thing I’m still debating how to do, is making the tank appear wet. It’s supposed to represent the vehicle when it was in the landing craft at sea, so I figure the upper surfaces would likely be wet from spray. Maybe a simple coat of semigloss varnish will do the trick, but I’ll need to experiment for that first.
