The difficult bits are done now (or so I hope …
). With the suspension done, for example, the rest of the hull can be built pretty quickly:
[ATTACH]477700[/ATTACH]
There are some oddities to be aware of here too, though. One is that the horizontal front plate, B20, is too wide. I had put the roof in (without glue) to ensure the width of the top of the hull was right. However, with B20 in place, it pushed the sides out far enough that I suddenly had a wide gap around the edges of the roof in front of the turret ring. Filing down both sides of B20 solved that.
Another minor thing is that the instructions say to put part T3 inside the drive sprocket, so it seems to be a poly cap. However, there is no sprue T, no loose poly caps, nothing. Because there will be a plate over the sprockets, you don’t need a poly cap to hold them to the axles, but it’s odd you’re told to add a part that isn’t included. (I did search my wheels-and-tracks spares box for suitable poly caps, but only found ones that either fit inside the sprocket but not over the axle, or fit over the axle but not inside the sprocket …)
That plate that goes over the left sprocket is C11, but the instructions don’t indicate the one for the right-hand side at all — not really a problem, as it’s self-evident, but it is sloppy. They also tell you to trim two lugs off of the plate (these hold the mudscraper that sits behind the drive sprocket), but on sprue S there are two identical plates that don’t have those lugs in the first place … However, my model uses the parts with the lugs, because the tank I’m building a model of did have them.
