Academy 1/25 Jagdpanther
    Hi All,
    [ATTACH]40611.vB[/ATTACH]
    Here's my build of Academy's Jagdpanther, quite decent value at £17! First impressions is that it's a pretty simple kit to make, pretty much a 'shake & bake '.
    Further inspection reveals it's a re-box of Tamiya's 70's kit, complete with the mouldings in the hull for adding a motor. The kit comes with working torsion bar suspension.
    [ATTACH]40610.vB[/ATTACH][ATTACH]40613.vB[/ATTACH]
    The drive sprocket housing is attached to the hull by 2 small screws! You can see the gearing inside the housing that's clearly a holdover from the days of motorization.
    [ATTACH]40614.vB[/ATTACH][ATTACH]40615.vB[/ATTACH]
    The rear equipment boxes have some small sinkholes, but some filler will sort them out.
    [ATTACH]40612.vB[/ATTACH]
    More to follow!
    Thanks for looking
    Patrick
    [ATTACH]44284.IPB[/ATTACH]
    [ATTACH]44285.IPB[/ATTACH]
    [ATTACH]44286.IPB[/ATTACH]
    [ATTACH]44287.IPB[/ATTACH]
    [ATTACH]44288.IPB[/ATTACH]
    [ATTACH]44289.IPB[/ATTACH]
    looking good so far, and quite good price!
    always loved the look of the Jadpanthers.
      This will be a cracking build, and a great scale also....looking good,will be following this one Patrick.
        This is going to be excellent if that King Tiger of yours is anything to go by.
        p.s. I have lots of wartime photo refs so give a shout if you need any inspiration
          • 18266
          I would of filled those screw holes and glued it on, Either that or its going to need a big dollop of mud!
            Ian, I did consider filling the holes but then I couldn't be bothered! Mud hides a multitude of sins!
            Kieran, Ray, Alex, many thanks & hopefully it'll turn out ok. It's really the scale that time forgot as I'm having trouble finding any crew figures so if anyone knows of any 1/25 or 1/24 German tankers, let me know!
            [ATTACH]40630.vB[/ATTACH]
            Filled the sinkholes with Tippex!
            [ATTACH]40631.vB[/ATTACH][ATTACH]40632.vB[/ATTACH]
            Made a start on the upper hull.
            Thanks for looking
            Patrick
            [ATTACH]44304.IPB[/ATTACH]
            [ATTACH]44305.IPB[/ATTACH]
            [ATTACH]44306.IPB[/ATTACH]
              • 22770
              A great start Patrick
                After a minor disaster with my Pershing, it's been retired to the back of the class in disgrace, so it's onward with my new star pupil!
                After finishing the lower & upper hulls, the primer went on. I want to experiment with the use of colour in this one, so for the lower hull I've used Tamiya Flat Earth mixed with a little Red Brown. The idea here is to increase the area that is normally in shadow & build on that. Though if I use the supplied Shurtzen, this area won't be visible! A thin over spray of Dark Yellow will lighten this section & pick out the detail (hopefully!).
                [ATTACH]40766.vB[/ATTACH][ATTACH]40767.vB[/ATTACH][ATTACH]40768.vB[/ATTACH]
                Just for a change, I thought I'd try some pre-shading. This is the first time I've even held an AB in over a year - and it takes some time getting used to it again!
                [ATTACH]40769.vB[/ATTACH][ATTACH]40770.vB[/ATTACH][ATTACH]40771.vB[/ATTACH]
                A few more....
                [ATTACH]40772.vB[/ATTACH][ATTACH]40773.vB[/ATTACH][ATTACH]40774.vB[/ATTACH]
                That's it for now until the Dunkelgelb goes on tomorrow!
                Thanks for looking
                Patrick
                [ATTACH]44438.IPB[/ATTACH]
                [ATTACH]44439.IPB[/ATTACH]
                [ATTACH]44440.IPB[/ATTACH]
                [ATTACH]44441.IPB[/ATTACH]
                [ATTACH]44442.IPB[/ATTACH]
                [ATTACH]44443.IPB[/ATTACH]
                [ATTACH]44444.IPB[/ATTACH]
                [ATTACH]44445.IPB[/ATTACH]
                [ATTACH]44446.IPB[/ATTACH]
                  good job m8
                  mobear
                    Just watching and enjoying
                    Roman
                      A small update, got the upper hull painted in dark yellow. It's a bit blotchy at the moment, down to both my rather rusty use of the airbrush & I think, some clogging. However, that will be sorted later in the build!
                      [ATTACH]40949.vB[/ATTACH][ATTACH]40950.vB[/ATTACH][ATTACH]40951.vB[/ATTACH][ATTACH]40952.vB[/ATTACH]
                      And some pics of the exhaust. I had to drill them out a little, so after that I painted the pipes with a couple of coats of Humbrol #113, then masked them for spraying with the hull colour. I'll return to these later for finishing with oils & bicarbonate of soda
                      [ATTACH]40957.vB[/ATTACH][ATTACH]40955.vB[/ATTACH][ATTACH]40956.vB[/ATTACH][ATTACH]40953.vB[/ATTACH][ATTACH]40954.vB[/ATTACH]
                      Thanks for looking
                      Patrick
                      [ATTACH]44612.IPB[/ATTACH]
                      [ATTACH]44613.IPB[/ATTACH]
                      [ATTACH]44614.IPB[/ATTACH]
                      [ATTACH]44615.IPB[/ATTACH]
                      [ATTACH]44616.IPB[/ATTACH]
                      [ATTACH]44617.IPB[/ATTACH]
                      [ATTACH]44618.IPB[/ATTACH]
                      [ATTACH]44619.IPB[/ATTACH]
                      [ATTACH]44620.IPB[/ATTACH]
                        cool paint job so far,v nice m8
                        mobear
                          Looking real class mate, very nice work.
                          Robert
                          • Centurion3RTR
                            • Jan 2009
                            • 2093
                            Lookin' good Patrick as always mate, nice work on the exhausts.
                            Have fun, John
                              its coming together really nicly.
                              Am seeing the nice pre shading. looks like a good job
