Another First - 1/35 CH2 TES.
  • Waspie
    • Mar 2023
    • 3488
    • Doug
    • Fraggle Rock
    I have never - ever even attempted to have a go at armour. But after working at Bovington, the home of the Armour Corp, I thought I would have a go at the clanky machine that deafened me every day!! (I must admit the TES variant hadn't arrived by the time I retired).
    So here go's.
    First impressions were favourable but since opening the box and getting started I have moved away from favourable to Mmmmmm!! Too much waste plastic getting in the way of the build. Also - too much to remove from individual parts, lots of filing, smoothing to establish a nice fit!! That said, I'm enjoying the additional work. Spending more time on this that the Sea King.
    Couple of pics.
    Inside the box and the dreaded PE!!!!!
    Hull started -
    I would have been further advanced but chasing a manic 14 week old puppy around whilst sorting bits out hindered progress!!!!
    In case you missed it on another thread the surplus plastic - everywhere!!!!!!
    Those half-round bits on the inside are where the knock-out pins push against the part to remove it from the mould. If they’re not in the way, leave them be Chances are the ones at the very front and rear might interfere with the fit of the nose or rear plate, but you’ll find out quickly enough by just holding the parts together without glue. If they are in the way, just snip them off.
    As for the etched bits, if you’re not feeling up to it, check the instructions carefully to see if they give you the option of plastic or etched bits.
    • langy71
      • 1950
      • Chris
      • Nottingham
      You've gotta love a Challenger, I'm sure you'll wrestle this into a cracking build.. incidentally is this the TAKOM Chally 2...(been looking at getting this for a while...so it's all riding on you buddy... )
      (grabbed a chair near the door to keep an eye out for Maton.)
      • Mark1
        • Apr 2021
        • 4156
        Like the look of this, and what jacko said, if your not confident with the etch and dont have to use it then dont bother, you can still turn out a nice build without it .
          The PE can be very intimidating, the larger pieces are easy to handle - it's the smaller pieces that give trouble! One thing - just because the PE part is on the fret, doesn't mean you have to use it! Ask yourself if the PE adds to the model - if it doesn't leave it. PE can be superb for grilles etc, but at times makers seem to add stuff just to fill the sheet up!
          One thing you should do is prepare the PE, I always clean mine with IPA ( Isopropyl Alcohol ) to thoroughly degrease the part..............
          • Waspie
            • Mar 2023
            • 3488
            • Doug
            • Fraggle Rock
            Originally posted by Jakko
            Those half-round bits on the inside are where the knock-out pins push against the part to remove it from the mould. If they’re not in the way, leave them be :smiling3: Chances are the ones at the very front and rear might interfere with the fit of the nose or rear plate, but you’ll find out quickly enough by just holding the parts together without glue. If they are in the way, just snip them off.
            Thanks Jakko, I removed them all because it was easier to ensure it all fitted together. As for the etching!! I'll see how I get on with the limited tools I have. :thumb2:
            Chris, this kit is a Ryefields version of the Chally, Hope I will do it justice.
            Originally posted by Mark1
            Like the look of this, and what jacko said, if you're not confident with the etch and dont have to use it then dont bother, you can still turn out a nice build without it .
            Well Mark, I have a further 3 stages to go before I encounter any PE, don't think I'll be able to touch it tomorrow seeing the mem-saab's itinerary. Not going to rush it. If I mess up the PE then that's the way it goes but I don't intend messing up!!!!
            Thanks for the advice regards the IPA Dave. I'll add that to my list of items required if I haven't already got it under a trade name or something!!!
            • JR
              • May 2015
              • 18273
              Big change Doug from wingy things , but you take your time and enjoy.
              Seat at the front please. Any chance of a tea please ?
              • Waspie
                • Mar 2023
                • 3488
                • Doug
                • Fraggle Rock
                Happy to have you onboard John. Hobnobs or choccy digestive. Sorry, Bourbons all scoffed!!!!
                • Mark1
                  • Apr 2021
                  • 4156
                  Theres always loads of pe tutorials on utube if you want see how its done
                  • Mark1
                    • Apr 2021
                    • 4156
                    Oooh choccy digestives, that packet wont be big enough if im about lol
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      Packet singular!! Oh I think not!!! Mem-saab is deadly around kits but I never knock her supply of biccies.
                        You don’t need a lot of sophisticated tools for working with etched parts, though some of those can make your life easier. At a minimum, IMHO you need a good knife, flat long-nosed pliers and a small flat file. Something like a glazed tile, a steel ruler and medium-grit sandpaper will also help.
                        What I normally do is remove a part from the fret by cutting through the tabs that hold it to it with the knife. Do this carefully, and if necessary you can use the steel ruler to press the fret and part flat against your cutting mat when cutting through the tab. Once it’s free, hold it in the pliers so that just the tab and a fraction of a millimetre of the part sticks out, then carefully file off the tab.
                        If you need to fold parts into shape, you can hole them in the pliers too, with the fold line as close as you can get it to the edge of the pliers. Then bend over with your finger, or use the steel ruler. With a piece too large to fit in the pliers, put it on the tile and lay the steel ruler along the fold line, then press firmly down on that and lever the free end of the part up with the edge of your knife. This takes care and some practice too, BTW.
                        Usually, the idea is that the fold line goes on the inside of the bend, but check the instructions carefully in any case to make sure you’re bending parts the right way — you could end up assembling something as a mirror image of what it’s supposed to be, and it will then be hard to get it back the right way around. Chances are some fold lines will break, for example, and even if they don’t it will be difficult to make everything nice and flat again.
                        The sandpaper is to rough up the surfaces where the part will be glued. It’s often best to do that while it’s still on the fret, but be careful that you don’t bend the part or even adjacent ones or the whole fret!
                        • The Smythe Meister
                          • Jan 2019
                          • 6248
                          Don`t do Modern Armour myself,(although i do have a Chieftain in the stash!:nerd,
                          But i`m always up for watching an AFV build,and this looks it will be interesting:thumb2:....... no biscuits for me mind thank you.......
                          ........ i`m strictly "Pasty only" .
                            • 15709
                            I'll follow this build with interest Doug. The kit looks nice and I'm sure if you take it steady the PE will be fine.
                            • Waspie
                              • Mar 2023
                              • 3488
                              • Doug
                              • Fraggle Rock
                              Cor, thanks for taking the time to explain the process so well Jakko, very much appreciated. Whilst not getting to grips with the kit today, I did spend what little time I did manage to sort a few tools that would fit the bill nicely. (I hope). I don't have a metal rule but I do have a metal trimming tool for wallpapering that will suffice.. Also a nice set of snipe nose pliers, a Stanley knife blade.
                              I am developing a theory that I may put into practice. A 6 inch engineers square which I thought - clamp to bench forming a solid base. Then using the Stanley blade, carefully bend the PE!!
                              Let you know how I get on with that when I start the PE.
